IC7300 Manual Released
The manual has been leaked/released, it appears. Interesting read, as we finally get an idea of it's receive capability. I'll let you all be the judge...http://www.mwe.dk/IC-7300.PDF
«13
  • k0eoo
    k0eoo Member ✭✭✭
    edited March 2017
    I notice in the receive specifications that the 7300 has a 36kHz IF??  If that's the case its not using DDS as they advertise but has a Direct conversion front end with base band A/D conversion like the Flex3000/5000....
  • Rob Fissel
    Rob Fissel Member
    edited February 2016
    It says it's using a direct sampling superhet on receive.... so yeah...
    Spurious and image rejection not even close to the 6300, let alone the 100dB in the 65/6700.
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    edited January 2017
    Its target market is the Ic706, ic7000 Low cost not world class performance. Looks like a 1st generation SDR
  • Barry N1EU
    Barry N1EU Member ✭✭
    edited December 2016
    It's direct sampling RF to digital.  They just digitally re-sample to use their already existing 36KHz dsp software library.
  • Barry N1EU
    edited February 2017
    It IS direct sampling.  I say it's going to be an excellent low cost radio but as far as SDR, it will have worst-in-class spectrum display - very low resolution.
  • Walt - KZ1F
    Walt - KZ1F Member ✭✭
    edited March 2017
    Is the  bar for that now at UHD for spectrum display? It shows where stuff is....doesn't need to be UHD. It might **** the TS-590. I suspect there is still a solid 6 months before anyone can discern what impact, if any, it will have. I don't suspect Kenwood, Yaesu, Icom consider Elecraft a major manufacturer either. Kinda like Ford, Chevy, Toyota, and Honda not considering Tesla a major auto manufacturer either....huh Howard?
  • Barry N1EU
    edited April 2019
    No, the bar for that now is something better than this:
    Inline image 1
    Yup, that's actually as good as the IC-7300 display gets, even on an external monitor.  Reminds  me of the Ten-Tec Orion Sweep circa 2002.
  • Walt - KZ1F
    edited November 2016
    Barry, did you mean that to be simply text? "Inline image". It looked fine to me, plus, it's software, they can spend a few more hours and make it better. It took me a bit of time to get the spectrum and waterfall really sexy.
  • EA4GLI
    EA4GLI Member ✭✭✭
    This is the actual diagram http://forum.qrz.ru/attachments/338-ic-7300/158703d1456442991-ic-7300-ic-7300_schematic_diagram_0.pd...
    of the 7300 if anyone is interested in analyzing it.
  • Walt - KZ1F
    Wow...when is Heathkit going to come out with it's version of this?
  • DrTeeth
    DrTeeth Member ✭✭
    edited December 2018
    I have recently come across (wink) a collection of 500 Ham Radio equipment manuals. Some are quite old. I will do requests, my email is good on qrz.com.
  • Barry N1EU
    Walt, are you not seeing the panadapter image posted?  I see it fine here.
  • Gerald-K5SDR
    Gerald-K5SDR FlexRadio Employee ✭✭
    The 7300 uses a 4.3 inch diagonal TFT display. Maestro has an 8 inch diagonal WXGA IPS HD display for comparison.  As you all know, you can scale the SmartSDR display to virtually any size and resolution.
  • Walt - KZ1F
    Barry, no. I am just seeing the text "inline image 1", with no associated inline image.
    Gerald, if you are responding to my comment. I was not comparing a $1500 radio with a $7500 radio. But, similarly, I was not comparing a $1500 radio with a $1200 GUI.
    Actually, the **** of my comment was sort of a response to someone's thread where they were going to put up a 55" $3000 UHD tv as a monitor for the 6x00. Now that is how I spell devotion.
    Barry, the picture of you, the 6x00 images to the right, the blue submit button all come through fine...just your "inline image 1" doesn't.
  • Barry N1EU
    Walt, perhaps it's the browser you're using.
  • KF4HR
    KF4HR Member ✭✭
    The IC-7300 looks like a down sized entry level version of my IC-7800 (which by the way has been collecting dust since I received my Flex-6700).  The 7300 seems a tad too large to be a replacement for the IC-706 series, IC-7000, or IC-7100.  My guess is, this is ICOM's attempt to test the SDR mid-to-lower end market.
    As for displays.  IMHO FRS has pretty much thrown down the gauntlet when it comes to spectrum displays.  Adding a large UHD screen, while not absolutely necessary, for me is just icing on the cake.  I enjoy the flexibility of the Flex spectrum display and that any sized screen can be used.  Price aside,  I much prefer tuning viewing a large high resolution spectrum display, than looking at a frequency dial and a run-of-the-mill small screen band scope with minimal viewing capability..., but I'm guessing I'm preaching to the choir. :^))
  • Walt - KZ1F
    Not likely.
  • Barry N1EU
    Here's a spectral display that has my appetite whetted, SDR-Console v3 being driven by Flex 6500 DAX IQ:
    (software is not yet available)
  • Walt - KZ1F
    BTW Barry, that came through fb.
  • Walt - KZ1F
    The other thing about that Barry, beyond being pretty, what does that convey.
  • Barry N1EU
    In a nutshell:
    lower left shows AGC curve (SSDR AGC parameters are a mystery)
    upper left shows tx audio spectrum of tuned station
    waterfall looks like SSDR except it adds two vertical lines showing your rx passband   -  I find it easier to tune in a signal with this than a mouse pointer
    panadapter shows:
        peak hold in yellow outline
        rx passband highlighted (like SSDR)
        panadapter trace is color coded for signal strength (mainly just looks very cool)
  • Walt - KZ1F
    Do not misunderstand Barry, I think the graphics are awesome. As I said earlier, it took me some time to get a 7 color waterfall to look 'right'. So this is colorizing a spectrum display, on the technical merits, it is, also, awesome. But cpu/gpu wise, it is expensive and my question was sincere, what does it endow to an pan spectrum display more than what a drawLine does. I was toying with the idea, just for poops and giggles, making a 3d spectrum display. (nothing FRS couldn't do) but I questioned the value add over a waterfall. I have never, in my entire working career, done true graphical software, ala what you show or, frankly, what I've done in the last however many months. This, visualization, is a fascinating subfield of software development.
  • Takeshi Yamada
    Takeshi Yamada Member ✭✭
    edited March 2016
    My friend reported that IC7300 preforms very poorly under the high level of input.   He uses 80 meter long windom antenna that yields +3dBm input of 882Khz commercial broadcasting station.   The 4th order of the signal, 3528Khz fall into 3.5Mhz band with S9+ signal strength.   He needed >15dB external attenuator to eliminate such problem.  It is supposed to be caused by the PIN diode switch ICOM uses at the front-end.   Flex6500 did not show any of such problem under the same operating condition, of course.
    73 de JI1BNU
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited February 2018
    It is not really fair to compare it with the Flex, It seems to be very entry level. But what I do like is it being an SDR mobile radio.
  • Cal  N3CAL
    Cal N3CAL Member ✭✭
    I doubt any TS-590 user would give up their radio for a 7300!   They may be in the same price range but the 7300 has only one antenna port!
  • Barry N1EU
    The image is visible to me from multiple computers/locations/browsers.  Anybody else not seeing it?
  • EA4GLI
    EA4GLI Member ✭✭✭
    I don't see it either
  • Barry N1EU
    okay, sorry Walt and Sal.  Don't know what to do about that.
  • Rob Fissel
    Rob Fissel Member
    edited March 2016
    Barry, I don't see it on the actual thread page, but the picture displays correctly on the email I got regarding your post. Strange.
