CW Skimmer no longer tracking frequency after update to 1.6.21,
Ed
Ed Member ✭✭
edited October 2019 in SmartSDR for Windows
CW Skimmer no longer tracking frequency after update to 1.6.21, Does not change frequency display if radio changes band or or frequency in a band??
see signals in window but frequency stays the same even if I change bands. Can not click on a signal and have radio frequency change. Appears to not being talking between 6300 and CW Skimmer anymore.
Any help would be great!!!...Ed
  • DH2ID
    DH2ID Member ✭✭✭
    edited March 2017
    Ed, how are you connecting CW Skimmer to SmartSDR? Try this http://www.qrv.com/sdrbridge.html Alex -DH2ID
  • Al_NN4ZZ
    Al_NN4ZZ Member ✭✭✭
    edited March 2017
    Hi Ed,
    Are you using SDR-Bridge?
    Frequency display and tracking problems are often incorrect Telnet settings.
    Some more notes about SDR-Bridge and CWS setup here:
    https://community.flexradio.com/flexradio/topics/cw-skimmer-sdr-bridge-setup
    Regards, Al / NN4ZZ
    al (at) nn4zz (dot) com
    6700 - HW.................... V 1.6.21.77
    SSDR / DAX / CAT...... V 1.6.21.159
    Win10
  • Ed
    Ed Member ✭✭
    edited February 2016
    Resolved by after many tries to get it working I used the slash and burn method. Deleted SDR-Bridge and CW Skimmer then reinstalled with new copies. Now up and running. Hopefully will not come back...Thank You...Ed
  • Mike NN9DD
    Mike NN9DD Member ✭✭
    edited October 2019
    I noticed a few oddities but was able to get them fixed when it happened by grabbing the pan adapter with the mouse and shaking it back and forth for a short second and all come back in line. Most notably what I was noticing was the pan adapter and the water fall didn't line up. Running latest flex update, sdr bridge and skimmer. Didn't think much of it but when I saw this thought it was worth mentioning. Mike N9DFD
  • DH2ID
    DH2ID Member ✭✭✭
    edited December 2016
    My workflow for CW Skimmer:
    1. Start one of my WinKeyer profiles, which has DAX I/Q set at 96k
    2. Start my ZLP electronics CW Keyer
    3. Start HRD Digital Master CW-WinKeyer
    4. Start SDRBridge with CW Skimmer set at 96k
    5. Tune once to a preset frequency from CW Skimmer
    Signal is spot on, you can cklick-tune frome all three programs now
    (SSDR,DM,CWS)
    Alex - DH2ID
