N1MM Bandmap issue only on 15 meters.
Terry K8EET
During this week end's DX contest the N1MM Bandmap did not display any spots on 15 meters. Hard to see how this is a Flex problem, but I wonder if others experienced this. (Only on 15 meters, other bands were fine.)
Terry: Any chance the checkbox for that band was unchecked in the Telnet window under "bands/mode" tab? Sounds obvious, but that happened to me during the contest, and I overlooked the obvious while triple checking everything else!
73, Tom
K1FR
Thanks Tom,
That was it. Not sure how it got unchecked. Don't think of the simple things in the heat of the battle.0 -
Side question, Tom. Any idea on how to get multiple instances of CW Skimmer to send spotting information via Telnet to N1MM. Ran as SO2V with the 6300 and because both instance of Skimmer used different ports, only one instance would send spots over... hope that makes sense!0
Rob: Yes - I had it up and running with two skimmers and with one skimmer and one cluster reporting. Really slick. Suggest you search for DK1EY's excellent post on the subject. I found that VE7CC's utility program was easy to use. Not much luck with the alternate of WintelnetX. Let me know if I can help.
73, Tom
K1FR
Perfect, will do Tom. Thanks for pointing me in the right direction.0
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
