CAT Command ZZMD
Lou N2TU
CAT Command ZZMD. My understanding was that most Kenwood commands will work with the 6500.
Logger32 sends a ZZMD6 to the 6500, attempting to put the rig in the RTTY mode. According to the Kenwood CAT command directory, this should set the radio to (FSK) RTTY. In the 6500 CAT directory, the ZZMD6 equates to AM.
So either the Kenwood CAT directory is wrong or the Flex CAT directory is...or heaven forbid, I am interpreting this info incorrectly!
Either way when a MD6 is sent to the 6500, it puts the rig into the DIGL mode and I want it to go into the RTTY mode!....
Any help?....am I missing something here?
Lou N2TU
Lou N2TU
Flex6xxx has a FSK mode?0
You need ZZMD30 for RTTY mode.
in circuit description only1
Thank you!0
... on paper was correct :-(0
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
