SmartCAT 1.6 potential issue
dlwarnberg
Hi all,
Been tinkering a bit and came across something. First let me say this new install after a full system cleanup of SmartSDR 1.6 and no ghosted com ports..
First I went to add a com port, next in line was com10 however it wanted to make it com11 not com10.. I searched and searched and could not find a cause.. no hidden or ghosted com ports, nothing in registry.. when I finally did get it to add a com10 after reboot system showed com11 with a hidden com10 port now on the system..
Next issue I came across was editing an existing com port.. com5 was setup but has slice A selected, wanted to change it to slice B.. selected it, edit slice A to B, save and the system hung... had to reboot.. came back and no more com5.. but com11
So to fix all this so that it would work I removed all listed com ports and rebooted, then added them back one by one.. it still wants to skip com10 and go to com11..
Very odd..
David
Very odd..
David
David, open a helpdesk ticket. It sounds very similar to an issue I had and it did require some Flex magic (aka Tim) to fix.
The saga continues.... rebooted this morning and all com ports are gone accept... you guessed it.. com11
Ticket opened0 -
You have a Magic PC David, i suggest to open a ticket in HelpDesk.I use Win7 - Win10 - Win10Pro Preview and no issues with COM ports/ DAX and others from Flex. i think you need dedicated advise from FRS.
check this out
I have this problem, anyone have an idea of the error cause.
I also saw a setup here for Fldigi and WSJT, where is it?
so.. another observation.. I went ahead and removed the ports in Device manager and rebooted.. they are all back0
Burt, can you select the com port and then hit log to see whats going on??0
David , COM 1 this is physical port ? This port activated via BIOS or disabled ? Have other COM VSP SW - Eltima ?0
Com1 is physical (in BIOS), Com 2 is USB (LP-100A), Com 3 is USB (Elecraft W2), Com 4 is USB for PowerCheck (west mountain radio)
I have no other COM VSP software on he system... all those ports are listed as FLexradio Virtual Serial Ports0 -
Looks like some how this port paired and next end is COM11, I suggest switch off COM1 to see what happens , try to delete this COM11 again and with disabled COM try to organize any pair in FlexVSP with COM11( in expert mode) where delete this pair after.0
With help from the helpdesk it's resolved but not resolved.. I can recreate the problem with attempting to add com10... here is what I did to resolve it (keep in mind if I add com10, a reboot shows all com ports gone in SmartSDR CAT but com11, but all previous ports show in Device Manager and NO com11)
1) Removed Flex Radio VSP
2) Removed all left over COM ports (FLEX, ghosted)
3) Rebooted
4) Checked again, com11 showed up in CAT, removed it
5) Rebooted
6) No odd com ports so reinstalled Flex VSP
7) Rebooted
8) all good so added ports back, com5 com6 com7, com8 and com9
9) Tested... all worked fine
10) Rebooted
11) All still good so decided to test.. added com10
12) Rebooted
13) All com ports GONE accept com11 showed up in CAT
14) Device manager shows all (ghosted or hidden)com ports accept com11 that shows up in SmartSDR CAT0 -
Ah the wondrous world of the Windows Registry. It's mystical and runs on Gravity waves BTW.
The log is blank but see attached1
Burt, if it where me this is what I'd do... remove the com port in SmartSDR CAT, then check your Device manager (show hidden ports and ghosted ports) and make sure it's gone. Then if it where me I'd go in and JUST remove Flex VSP app. After that reboot, check ports again in device manager, if all is good migrate to the install folder for your latest flex install, go to (mine happens to be on D drive)
D:Program FilesFlexRadio SystemsSmartSDR v1.6.2164-bit DriversVSP
in there you will find the "FlexVSPInstaller_64.msi" May be 32 in your situation, and run it as Administrator, this will reinstall for you.. reboot and setup you're com port again.
You do have a second option that may be simpler, in windows 10 (what I"m running)P if you right click on that FlexVSPInstaller_64.msi you can select "repair".. that might work as well.
David0 -
Issue officially resolved. After all this I went fishing some more... in the registry (not for the faint of heart), what I discovered is my neato vacuum's firmware updater created a virtual com port, usb to com, and you guessed it.. left a key in the registry for com10... it dos not show up as hidden, ghosted or anything in device manager yet caused this issue.. sheesh
So I uninstalled the software, checked the registry again... still there... AAAARRRRGGGGGG.. so I forcefully removed the key in the registry.. (dont try this at home)
Tested this morning and tada:
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
