Welcome to the FlexRadio Community!  Please review the new Community Rules and other important new Community information on the Message Board.
SDR Bridge 1.5 will not connect to radio
                    Bob  KN4HH
                    Member  ✭✭✭
                    I have been using SDR Bridge v1.3 with no problem.  I uninstalled v1.3 and installed v1.5.  When I execute 1.5, CW Skimmer comes up and eventually SDR Bridge comes up and says "not connected to radio".  The Slice and Stream boxes are gray.  I checked the setup and it agrees with my 1.3 settings with the exception of the new features.  I insured that DAX IQ channels are active and assigned to SDR Bridge.  I am not listing this as a problem since I usually suffer from a short between the headset, hi hi.
            No changes were made to the SDR-Bridge code that connects to the radio, and v1.5 is built with the latest version v1.6.21 of FlexLib. I'm not sure where the problem might be.
 Check to make sure SSDR, CAT, and DAX are all connected to the radio. Then start SDR-Bridge. If there is still a problem, try restarting the radio.
 73 Ed W2RF
            Ed, I knew it had to be something simple. My network was blocking SDR Bridge from communicating with the Flex. Interestingly, it did not block 1.3. All is working well now. Many thanks for your reply and for providing such a wonderful piece of software.
 73, Bob, KN4HH
            Hi Bob,
 Just curious about network issue that was blocking SDR-Bridge. I might add some notes about it to the next version of the quickstart guide.
 Did you get an error message?
 What version of windows are you running?
 What did you do to fix the issue.
 Regards, Al / NN4ZZ
 al (at) nn4zz (dot) com
 6700 - HW.................... V 1.6.21.77
 SSDR / DAX / CAT...... V 1.6.21.159
 Win10
            Ed, I am running Windows 10. I received a message basically saying "a program (SDR Bridge) is trying to access the network". It provided options such as "Do not allow access to the network (Recommended), or "allow access".
 Unfortunately, I do not remember any further context. Since no one else has reported this condition, hopefully this is an isolated case.
 Bob, KN4HH
- 355 Community Topics
- 619 The Flea Market
- 8K Software
- 14 SmartSDR+
- 6.3K SmartSDR for Windows
- 414 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 26 Aurora
- 221 FLEX-8000 Signature Series
- 927 Maestro
- 899 Genius Products
- 458 Power Genius XL Amplifier
- 325 Tuner Genius XL
- 116 Antenna Genius
- 287 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 980 Third-Party Software
