Maestro
Bob G W1GLV
Saw & played with the Maestro for about a half hour today at Hamcation. This is professional grade hardware. Just an elegant addition to any 6000 series radio.
3
Thanks for the report Bob. How is the feel of the knobs and pushbuttons/switches?0
Tim, the tuning knobs have a heavy feeling to them, which to me is great when tuning. The smaller knobs are of legacy radio quality and feel. The menu system is well thought out, no extra stuff that you seldomly use. The case is top quality.2
Might I add the display on the maestro was far beyond my expectations, very clear and larger then I expected... my2cents0
Bob, did you happen to notice if the dial shafts were metal or plastic?0
Any technical details?
- Software version of SmartSDR?
- devices such as Bluetooth headsets or keyboards connected?
- Was SmartSDR running simultaneously?
- Any hands on videos?
Bluetooth, yes (I think Tim said they are working on it more)...
Did not notice the software version of SmartSDR (drat forgot to look)...
They had SmartSDR running on a computer or two but I think all the Meaestro's were connecting via wireless to a stack of 6300 in the corner.
Did not take video or any pics but several did.. maybe they will share
David0 -
Thanks David!0
Seems the unit is top-shelf. Will see it next week at the Yuma AZ hamfest (unless production units ship sooner).
Thanks....
Tim
Metal knobs with rubber radius. Could not see the shafts.0
Software version same as radio.0
Thanks Bob, that's encouraging. From what you've said they have 'mass'. I like dials and knobs and rocker switches that have mass, a solid feel. I suspect others will appreciate that as well.
Walt, I was talking to Dave WO2X on air. He said the large tuning knob is weighted much the same as a large rig would have, a good weight to it. He also said the build quality is first rate.0
Frankly Bill, that was my main concern. I don't like dealing with plastic things as we, as a society, have gotten used to based on lowest bidder manufacturing. So that is a huge plus in my book.
The reality is even though I rarely use two pans or, more than 2 slices, and only have ever used 4 to say I did, I did buy 4 and I'd like to not give 2 of them up. I'd get past the Windows OS so long as it wasn't in my face, which it wouldn't be w/Maestro but then I'd still need a computer for all the ancillary things like logging, device control, etc. I will likely sit out this version of it...for now. I am encouraged on the possibilities for the next generation Maestro, be it software or hardware.
Thanks Bob,
Sorry to have missed the Hamcation: I was planning to attend. However, my in law is not doing well and had to head up north to Georgia.
Thanks again for bringing us up to day on the Maestro.
Can't wait!!! de W3DCB Daniel
The main vfo knob is metal with rubber inlay as others have pointed out. If you spin it fast, the radio will continue to travel up or down the band very like traditional radios with larger VFO knobs. The weight isn't as much as a larger knob radio but very nice and well balanced for the size of the Maestro.0
Dave, does the tuning rate vary as you spin the knob faster? I believe someone posted that it's 64 steps per knob revolution, but does it accelerate beyond that if you turn, turn, turn?
Thanks, Barry0 -
I will check later but I normally use 1 kHz step on 75 meters and could way from 3.814 to 3.630 very quickly :-) it is also easy to change step size.0
Have not found a maestro video yet.
Maybe FRS or some ham will have one for us, who can't visit sunny Florida?
But I found this on Steve K9ZW's page:
https://k9zw.wordpress.com/2016/02/16/hamcation-2016-maestro-production-unit/
Alex - DH2ID0 -
I see from the data sheet that the mic connector on the rear of Maestro is an RJ-45. The mic shipped with my 6500 has an 8 pin foster connector. Is the mic socket wired as a Yaesu Modular or it is unique to the Maestro? If the former then we can use an adapter and not have to buy a whole extra mic.0
David, here
http://www.flexradio.com/amateur-products/flex-6000-signature-series/maestro/
it says: " Microphone 1: Pseudo-balanced 8-pin RJ-45, dynamic or electret compatible (Same “Yaesu type” pinout as FLEX-1500 and FLEX-3000)...Microphone 2: Pseudo-balanced 1⁄8” (3.5mm) TRS, dynamic or electret compatible...Microphone Impedance: 600 Ohms Nominal (200-10kΩ)"
I found that my YAESU M100A8X microphone is working very well with my
Flex-6500. It has a 8pin foster plug and a RJ-45 one and you can just turn
the cable around and plug it into either one. Great idea!
And FRS made the best out of it: My Flex 3k, which I use mostly for EMCOMM
and fielddays, has a RJ-45 connector and my Flex 6k5 the 8pin one.
I can therefore use my MD-100 with both of them!
73, Alex - DH2ID0 -
The RJ45 is wired Yaesu and Flex sells a replacement cable for the hand mic that has an RJ45 instead or 8 pin Foster. Price is about $12 and can be ordered when your Maestro ships.1
Thanks Alex ... I will buy an adapter cable now that I know. I use a PR-781 into the balanced connection on my 6500 so the supplied fist mic is superfluous for mist use but with the adapter it will be fine for the Maestro!
David G4NRT0 -
That is great to know. I was just going to suggest that very thing! I hadn't checked the accessories list in the flex store.
I wonder how long it will be before people suggest that the Maestro Mk II should be made so that it can be attached to the front of the rig. People may then like it so much that the Flex 7xxx will come with the Maestro permanently attached to the black box...and this is where Gerald Youngblood (K5SDR) came in. He would think that <cue Twilight Zone intro> he is in a time loop.
Sri chaps, couldn't resist.
- 352 Community Topics
- 617 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 187 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 23 Aurora
- 217 FLEX-8000 Signature Series
- 923 Maestro
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 285 Shack Infrastructure
- 200 Networking
- 138 Contesting
- 758 Peripherals & Station Integration
- 978 Third-Party Software
