Low Power 12 Meters
Lou N2TU
Lower power on 12 meters....
Tried this with two different power supplies....an Astron 35 and a SAMLEX 1235M. Each with its own Powerpole ****. No other unit plugged into the strips. West Mountain, not MFJ strips. In other words, two different set-ups. The Powerpole strips are within 5 feet of the power supplies and the original F6500 power cable is used. The Flex 6500 RF Power slider all the way to the right.
Using a LP100A and a Palstar DL2K dummy load, I get the following readings....notice the 12M reading.
160 102W
80 106W
40 103W
30 95W
20 98W
17 98W
15 90W
12 73W *****
10 93W
So the question is why the power drop on 12 m?
Any reasonable answer accepted! Hi Hi!
73/ Regards
Lou N2TU
160 102W
80 106W
40 103W
30 95W
20 98W
17 98W
15 90W
12 73W *****
10 93W
73/ Regards
Lou N2TU
I have had this happen to me on a couple of bands. I found a problem with my dummy load, so changed dummy loads and put an external wattmeter in line with the dummy load. This solved my problems. I have also had problems with occasional low output traced to RF feeback. Ferrite cores and better grounding solved this.0
Resonant length of coax. Try a different lengthy of coax0
Ground is excellent....copper braid...and a common junction point...no ground loops...and ferrites everywhere....
I used an external wattmeter...the LP100A...and the dummy load meter was within a few watts of the LP100A, so I am confident the reading is accurate. Also, the readings coincided with readings when the rig was connected to my antenna. Again verifying the accuracy of the readings.
Trying a different length of coax is out...seeing the readings are almost identical when using the antenna...
Thanks....
Lou N2TU
Next Guess... Gremlins....
Lou, I have the same situation on 12 meters. Did you ever resolve the problem? AA7SN0
- 378 Community Topics
- 117 SmartSDR+
- 37 Aurora
- 946 Maestro
- 923 Genius Products
