Heil Pro Elite headset
KC0EM
Hi,
I have a Heil Pro Elite headset I would like to use with my Flex. I visited a couple of ham dealer websites this morning and could not see an adapter for it to my Flex 6300. I’m sure someone else must be using this headset and wonder if I’ve have to a make one or there’s one available on the market someplace. I assume the “Default ProSet HC6” is the proper profile to use? Thanks for you help.
Use a Yaesu adapter. If I recall correctly, the Heil part number is AC-1Y.
73, Ray, K9DUR
This is correct. You can call Flex and order one too-I did since they did not offer just the adaptor on their website.
Heil Radio makes the adapters and can be ordered over the phone. The web site is http://www.heilsound.com/amateur/products/accessories/headset-adapters for the adapters and phone number. I have to caution you to be mindful of the alignment notchs of the male and female Foster connectors. Believe me, more than one person has misaligned these connectors.
I would start with the Proset 6 setting and tweak it from there to fit your voice and what you like to hear. It's OK to listen to what other hams say about your audio but there are many many variables on what is heard on different radios.
Ken
W0KRD0 -
I'm using that exact headset with my FLEX-6500 and previously on my FLEX-6300... mine in the NON Ic headset, if you have the Ic model headset it's a different adapter.
Pro Set Elite - 6 contains the Heil HC 6 full range dynamic broadcast element. The HC-6 is designed for commercial broadcast applications; the -3dB points are fixed at 100 Hz and 12.5 kHz, with sensitivity of -57 dB at 600 Ohms output impedance (centered at 1kHz). Using new dynamic technology, the HC 6 response can be equalized to match just about any requirement, from full range commercial broadcasting to serious contest and DXing.
it is the "yellow" adapter.. here is a link to AES where I got mine:
http://www.aesham.com/cables/heil-ad-1-y/
I have the Heil Pro 7 headset with the Yaesu adapter and use the Pro Set 6 settings without modification. Nobody has complained about my audio. Don't forget that you will need to use an adapter to get the 3.5mm headphone plug to fit the 6.3mm socket on your FlexRadio. I also have a Heil hand PTT switch with a 6.3mm mono plug. David G4NRT .1
Hi,
I want to thank everyone for their help. I had an adapter I had gotten someplace for the headphone part of the headset, so I used it. I love the way you can tailor the received sound using the Flex. It has helped a great deal in some of the CW contacts I've made. Particularly, when the elements are sent with very narrow spacing. I can eliminate the "run together" feeling of the sound. I suspect this may have something to do with my hearing problems. I use hearing aids. I am told the type of hearing loss I am experiencing is due to the fact I was exposed to loud sharp noises – gunshots, explosions, and etc.73 & Great DX
"VC"
KC0EM
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
- 295 Shack Infrastructure
- 207 Networking
