ATU issue
dlwarnberg
Although I think this is a minor issue I've discovered something. My radio is unlocked for MARS operation (FLEX-6500) on the band edges, the tune button will not work nor will the ATU properly..
example: I tune to 80 meters, LSB, freq 3.999 mHz hit tune, it works... change to 4.000 mHz, LSB tune will not hold, on off very quick.. now I know most wont have an issue.. however an unlocked radio a tune is a tune and should hold the tune so that I can use a remote tuner or hit the ATU button and get it to tune..
Another note, if I switch to USB, leave it at 4.000 mHz it will tune, so there is something right on the band edge that causing this.
Mine won't and I'd bet most cant test this as they do not have an unlocked radio.
David
David
Can anyone that has an unlocked radio confirm this??0
- 250 Community Topics
- 489 The Flea Market
- 7.4K Software
- 332 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 779 Maestro
- 42 FlexControl
- 733 Genius Products
- 254 Tuner Genius XL
- 86 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 119 Contesting
- 586 Peripherals & Station Integration
- 116 Amateur Radio Interests
- 810 Third-Party Software
