SmartSDR 1.6.21 CAT and DAX no longer start at boot.
KM6CQ - Dan
I just installed SmartSDR 1.6.21 Cat and Dax no longer start at boot up. I have to manually start them now. They are listed in the startup menu in task manager and enabled. I use a 6500 here running windows 10.
Any ideas?
Thanks, Dan
Any ideas?
Thanks, Dan
SmartSDR CAT Warning:
After installing new version I was able to Update my 6500 & DAX OK but seems to issue with VSP/CAT.
I have tried reinstalling but still get the same message?
Also running WIN 10.0 -
Dan, have you tried to install the FlexVSP driver manually from
c:Program FilesFlex Radio SystemsSmartSDR v1.6.2164 bit driversVSP ?
See here:
https://helpdesk.flexradio.com/hc/en-us/articles/205000829-Troubleshooting-FlexVSP-Not-Running-Error...
Hope this helps, Alex - DH2ID
If you continue to have issues after installing SmartSDR v1.6.21, I recommend opening a HelpDesk support ticket. For details on how to submit a HelpDesk support ticket, please refer to the following URL: http://helpdesk.flexradio.com/hc/en-us/articles/202118688-How-to-Submit-a-Request-for-Technical-Supp...0
Try disabling or uninstalling your anti-virus software if you're running something other than Windows Defender. A day or so ago, due to a non-Flex related problem, I installed PC-Matic and had the same problem crop up, something I hadn't seen for months. Uninstalling PC-Matic fixed the problem. I may have uninstalled SSDR & reinstalled it too, but I don't recall for sure.0
I have tried each and all of the recommended install procedures and still no luck. For some reason the VSP/CAT driver will not install?
Other than the VSP issue the rest of the install is fine. (DAX, 6500 Firmware, SSDR)?
I recommend opening a HelpDesk support ticket. For details on how to submit a HelpDesk support ticket, please refer to the following URL: http://helpdesk.flexradio.com/hc/en-us/articles/202118688-How-to-Submit-a-Request-for-Technical-Supp....0
Just opened one up.
Thanks0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
