Flex Control Aux Button Question
Lou N2TU
When I set up the FLEXControl Aux button to Master AF, it varies the Remote Volume. Is there anyway to change the AUX to something like this...?
AUX 1 Active slice volume
AUX 3 Second slice volume
Take it easy on me, I am a Flex Newbie!.....Hi Hi!
Hi Lou and welcome!
With SmartSDR you are limited to what functions you can assign. You can set the current (active) slice volume to be assigned to one of the keys but not for a second slice. The only way is to select the second slice and then use the knob.
If you have an iPad, you might be interested in K6TU Control
http://k6tu.net/ipad/k6tucontrol.html
which provides a virtual front panel for the radio. This makes touch access to all the controls very fast and doesn't require a mouse action and/or window focus change. You simply select the slice you want to control and then all the controls for that slice are literally at your finger tips.
Email me if you need help - you know where to find me!
Us TU's have to stick together!
Stu K6TU0 -
Stu....thanks!
Hope to see you soon!
Lou
But it sure would be a nice feature!...0
- 113 SmartSDR+
- 944 Maestro
