RadioSport head set won't PTT my 6300
David (AA9G)
Hi,
When I had a 5000 I bought a Radio Sport head set/boom w M207mic for it and it worked FB. Have now a 6300 and the pinout's are the same but my headset PTT will not key the radio. Any ideas on this?
Seems like to me it's a job for an ohmmeter and a jumper. Put a jumper across the pins of the PTT and see if the radio keys. Then put an ohmmeter across the connector on the headset and see if the PTT pins match.
Jim, K6QE
I love analog electronics.
Also, check the RCA jack of PTT in the back and make sure that keys the radio.
If you are plugged into the 8-pin "Foster" connector on the front panel, unplug and re-insert the plug, watching for the position of the plug. The jack is physically a bit loose to allow easy connection, but the plug can, in some cases by inserted with the nothch in the wrong position. Did that a while ago...1
ohh yeah - been there!!!! that causes all sorts of weird results !
Can someone be a bit more specific about using the jumpers please? I checked the RCA, it keys the radio. But I'm not sure what the second pin should be. The PTT and ????0
Ground.
Can you put an Ohmmeter across pins 5 and 6 of your headset and see if you get a short when you depress the PTT?0
- 311 Community Topics
- 566 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 385 SmartSDR for Mac
- 253 SmartSDR for iOS
- 241 SmartSDR CAT
- 176 DAX
- 364 SmartSDR API
- 8.9K Radios and Accessories
- 109 FLEX-8000 Signature Series
- 887 Maestro
- 49 FlexControl
- 841 Genius Products
- 433 Power Genius XL Amplifier
- 296 Tuner Genius XL
- 112 Antenna Genius
- 267 Shack Infrastructure
- 188 Networking
- 428 Remote Operation (SmartLink)
- 132 Contesting
- 686 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 914 Third-Party Software
