Will I be able to run my 6700 on a Maestro AND my PC at the same time?
Tim, am I confused by context regarding your answer above about the feature being "added" in a future release or are you talking about something other than CAT?
I use a tablet running SSDR for remote operation on my LAN & CAT on a seperate station PC to simultaneously interface my 6300 with PSTRotor, Steppir and an amp. I've been doing so since 1.4. It has always worked well.
Thanks!0 -
My answer was in response to Steve's comment "today only one "GUI client" allowed at a time"0
Meaning only one device (PC or Maestro) is currently able to display a Panadapter and Waterfall. GUI means Graphical User Interface. Which to most people means all of what is seen on screen, including various controls and the PanaFall display. So, saying only one "GUI" client at a time could be a bit confusing to those that may not know what is really being talked about. James WD5GWY0
Many changes in the last 6 years.
What is the setup to use a maestro (have both A and B models) to control a 6400 and 6700 as a big flex control? Equipment as a home station and as a club station.
Newest version 3 software in both locations. I tried various setup options but always wound up with two different panadapters rather than controlling a single SmartSDR.
Hi Stan, you need to put your Maestro into SmartControl mode. I am not sure how to do that exactly (I have no Maestro...), but if you look up SmartControl in the latest Maestro documentation, you should find it.
Each client creates it’s own panadapter. If two clients, each will have its own slice A, not an A and a B.
- 372 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 997 Third-Party Software
