SmartSDR v1.5 Settings not brought forward into v1.6
Dick B
I've noticed a couple of v1.5 settings that were not brought forward into v1.6 and wonder if there are more. My RX EQ settings were not brought forward although the TX EQ settings were. Also, my Display AVG setting was not brought forward. I noticed both of these within 24 hrs and wondering if there are other settings known to have been left behind and set to default values.
Both of these parameters are stored in the global profile database.
If you did an export of your 1.5.1 profiles prior to upgrading to 1.6, you can do a factory reset of the radio and import the 1.5.1 profiles which will convert them to the 1.6 format.0 -
Tnx Tim, if the export is in XML or some other relatively readable form I'd rather just scan it. I may have already made changes to other settings in v1.6 that resetting to v1.5 would undo. Otherwise I'll just live with it and discover any other differences as I go.
BTW. I discovered another one yesterday, The PROC compression level was not brought forward. I had to manually create a new Mic Profile with that setting. I expected the Mic settings to be brought forward in a new Mic Profile associated with my Global Profile, similar to the Transmit profiles.
- 390 Community Topics
- 662 The Flea Market
- 440 SmartSDR for Mac
- 55 Aurora
- 971 Maestro
- 946 Genius Products
- 308 Shack Infrastructure
- 216 Networking
