With SmartSDR v1.6, what is the "nifty" solution to hooking a voice keyer via N1MM+ while using a he
Wheelin Rev
Wheelin Rev Member
edited November 2017 in SmartSDR for Windows
With SmartSDR v1.6, what is the "nifty" solution to hooking a voice keyer via N1MM+ while using a Heil ProSet headset on the "BAL" (balanced) input? I thought there was a FLEX-written document on this but I can't find it now. I may have been dreaming too. LOL! Does anybody have this "new" method working and if so, can you share how to make the necessary configuration with N1MM+ and the voice WAV files. Thanks in advance (TIA) es 73, Dave K4EET
  • Al K0VM
    Al K0VM Member ✭✭✭
    David,
      These N1MM+ set up may help
    Plug your mic in as normal and record on the fly. Playback will select the Dax port.
    AL, K0VM
  • Fred-NA2U
    Fred-NA2U Member ✭✭
    edited January 2017
    AL, I'm new to Flex and new to recording voice messages in N1MM+.  Now with the 6300 I think I stand a chance.  I notice, however, that I don't have "DAX MIC Audio (FLexRadio System" option in my Audio Setup & Monitor Message Recording menu.  I do have "DAX Audio TX 1 (DAX TX Audio)" in the Playback menu.  The amount of help I may need might go well beyond this but I thought I'd start here.  Is "DAX Audio RX 1" acceptable for Message Recording?
  • Al K0VM
    Al K0VM Member ✭✭✭
    Fred,
       Is 'DAX Mic Stream'  shown in the DAX control panel and is it turned on?  If it is not there, then there is a Flex DAX install problem.. If it is there, then check the Windows 'Manage Audio devices'
    if 'DAX Mic Audio' is not there then it could be a FLex DAX install problem or a WIndows problem.
    If it is there then there may be a N1MM+ problem..
    If you show 'DAX Audio TX 1' but not 'DAX Audio TX' then I think that means the version 1.6.17 of DAX was not installed correctly when you installed Flex 1.6.17..  What version is shown in the DAX Control panel.
    AL, K0VM
  • Fred-NA2U
    Fred-NA2U Member ✭✭
    edited January 2017
    I checked the DAX control panel  It indicated it was "Off".  When i clicked to turn it on it stayed off and now indicates a Driver Error.  It does NOT show in Windows Sound.  I'll open a help desk ticket.  Thanks, Al.  I may get back to you about recording once I get DAX fixed.
    73 from the desert,
    Fred/NA2U
