Logger for Waterfall
Jim W3IPO
Jim W3IPO Member ✭✭
edited February 2019 in SmartSDR for Windows
Does anyone know of any software for logging the waterfall over a period of several hours?
Is this something that could be configured with SmartSDR API?
Jim
W3IPO
  • Kevin LaFata
    Kevin LaFata Member ✭✭
    edited January 2016
    I know this might only be mildly helpful, but in the past I've used Audacity to record the IQ stream from a Flex 6300. I *think* it will allow you play back the file from an arbitrary position in the band, but there wasn't an easy way to determine the actual frequency at that point. And the files will get big very quickly.
  • Jim W3IPO
    Jim W3IPO Member ✭✭
    Worth a try.
  • Mark_WS7M
    Mark_WS7M Member ✭✭✭
    edited January 2016
    Hi James,
    It certainly could be done via the API but like Kevin said the files would get big rather fast.
  • K5CG
    K5CG Member ✭✭
    edited October 2018
    I hadn't thought of Audacity to record the IQ, interesting. I had heard elsewhere here that the DAX IQ can be piped over to HDSDR and that has an IQ recording feature in it already. Same issue in any case, you have no idea of the original center frequency on playback.
  • KD4HSO
    KD4HSO Member ✭✭
    edited February 2017
    I'm in the process of learning C++, and would like to write an gr-osmosdr driver for the 6000 once I learn enough  If that could be done, it opens up a whole ecosystem of GNU Radio based software, such as GQRX, which logs 24 hour waterfalls.  Baudline wall also process very large data sets.
    https://github.com/osmocom/gr-osmosdr
    https://github.com/csete/gqrx
    http://www.baudline.com/
