Access to all DAX channels on 6300
I can't answer for Flex, but if you think about it, when you install SmartSDR to your PC, it doesn't know which radio you are going to connect to. It only "find out" when you the run the program to attach to the radio. Some people have multiple radios, like a 6700 (that can talk to 8 slices) and a backup 6500 (that can only talk to 4)
As the 6300 only has two slices, then you can only "talk" to two DAX devices. However with the single install, you can talk to multiple radios and the DAX channels are available in the PC, for what ever you have.
Brent W8XG
The 6300 only has 2 slices. What would you connect the other 6 sets to?
Better to remove sets 3 through 8 to reduce the obvious confusion.0 -
This is a very good point Bob as I've wondered that. Would it make sense to configure different Dax channels for each different 3rd party application we use, like FlDigi and WSJT, etc. ? This new version as tied me in knots primarily because of the new method of handling CAT/Com. I've had a real struggle getting things to work, especially the flex control which still doesn't work.0
Interesting point. Seems like one can only assign one DAX channel to each slice. However, you can delegate more than one piece of software ware to the same DAX channel. I am using a single DAX channel to stream audio to my iPhone using the Broadwave streamer, and the same channel to my Romac equalizier. I can't see where it would be to my advantage to delegate more than one DAX channel to a slice. However, it wouild be nice to be able to have more control over the remoted audio stream. It seems it can be attached only to the default speaker designee. It would be nice if it could be singularly identified like a DAX channel so it could be associated directly with multiple third party software.
Jim, K6QE
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
