WinForms test app.
Great news Vern. I sometimes forget about iconic.zip. If all else fails, there is always a copy of it in the Smart SDR install folder that you can copy and paste into your project folder to reference in your projects. Just remember, COPY & PASTE. Don't delete it from SSDR's install folder or SSDR won't run!
WD5GWY0 -
James: Good day! The iconic.zip will not install. I note that "References, Properties has a listing "C:UsersVernDesktopJames 01 WorkingCSharpFlexExampleFLEXLIB library for James Example jan-18-16ionic.zip.dll". Note the title 'ionic.zip.dll?
That differs from additional info in "ionic.zip 'Reference Proprities'" that says the (name) & identity is 'ionic.zip'.
In Solution Explorer I right click the program name and click on Add Reference. Then click on iconic.zip.dll. It installs in
'WorkingCSharpFlexExample, References'. Good or bad?
Vern
Sorry I missed this post Vern. You did right adding the ionic dll. I apologize for not responding sooner. James0
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
