All SDR CAT ports show error
Bob  KN4HH
Bob KN4HH Member ✭✭✭
edited June 2020 in SmartSDR CAT
The SDR CAT Com port list under V1.6 shows COM ports 4,5,6 and 7 have been created.  However, the red Error message appears on all ports.  When I hover over the error message for COM4, it says "has COM14 open which is needed by this port".  Could someone interpret the error message and what I need to do to eliminate it.  I have nothing connected to these ports at present.
Thanks, Bob, KN4HH
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    edited June 2020
    Are these hold-over ports from a previous installation?
    If so, they may not have gotten translated properly.  You might need to delete them all, close CAT & SSDR, reboot, and recreate them.  It doesn't take long.  If that doesn't fix them, see Tim's excellent article about eliminating "Phantom" or "Ghost" COM Ports and Audio Channels.
    Ken - NM9P
  • Al K0VM
    Al K0VM Member ✭✭✭
    edited November 2017
    Or you could Select Com4 for edit ( or add) and then right click in the edit (add)  window to get advanced and then change com14 to com104. and save.
    AL, K0VM
  • Bob  KN4HH
    edited January 2016
    I tried your suggestion by deleting the com ports using SSDR CAT Remove command.  No success with creating new ports.  I then followed Tim's procedure for deleting phantom ports, of which there were several, and re-booted the computer and restarted SSDR.  Now when I try to Add a port in CAT, I get a message "VSP failed to create".  I suppose it wouldn't hurt to reinstall SSDR including VSP.
    Bob, KN4HH
  • Ken - NM9P
    edited December 2016
    On the Flex Net yesterday, Dudley told someone to go to the Windows>Programs and Features> and Find FlexRadio Systems FlexVSP and right click on it and select "Repair" and let it rebuild FlexVSP.  I would suggest a reboot before and after you do this.
    See if that helps.  If not, then you might need a total removal and reinstallation.
    Ken - NM9P
  • Al_NN4ZZ
    Al_NN4ZZ Member ✭✭✭
    edited March 2017
    Bob,
    I had the same error when trying to creating ports.  Discovered I had the old VSP driver 1.0.1 installed.  This may be worth a check.  You can see the version by using Windows control panel and the "uninstall or change a program" option.
    Here is what I did that worked if you have the old version and I didn't have to reinstall all of SSDR.
    Stopped all Flex related programs CAT, SSDR, DDUtil, etc
    Use control panel to uninstall a program and remove VSP V1.0.1
    Reboot the PC
    Re-install just the driver, using this link since my PC is  Win10 64 bit.
     C:Program FilesFlexRadio SystemsSmartSDR v1.6.1764-bit DriversVSP
    The new version is now 1.0.2
    Started up CAT and added a port Com10 / 110
    No errors, started up all of my Flex related software (DDUtil, SSDR, SDR-Bridge, CW skimmer)
     and everything seems to work,
    Then did a test on the new CAT port Com10 using the LOG option and tested using FA;.  Freq date returned as expected.
    Regards, Al / NN4ZZ
    al (at) nn4zz (dot) com
    6700 - HW.................... V 1.6.17.74
    SSDR / DAX / CAT...... V 1.6.17.156
    Win10
  • Al_NN4ZZ
    Al_NN4ZZ Member ✭✭✭
    edited March 2017
    By the way, the reason I had the old version of the VSP driver is my habit is to install the new SSDR versions without "un-installing" the current one.
    Per Tim E., at some point in the past there was a VSP update as part of an SSDR release.  And the only way to get it was to un-install and re-install SSDR.
    So it's worth a check to see if you have the old version V 1.0.1
    Regards, Al / NN4ZZ
    Win10
  • Bob  KN4HH
    edited May 2017
    Thanks, guys.  It was a combination of problems starting with old defined ports and old VSP driver.  All is well now.  I really appreciate all the helpful comments.
    73, Bob, KN4HH
