All SDR CAT ports show error
Bob KN4HH
Member ✭✭✭
The SDR CAT Com port list under V1.6 shows COM ports 4,5,6 and 7 have been created. However, the red Error message appears on all ports. When I hover over the error message for COM4, it says "has COM14 open which is needed by this port". Could someone interpret the error message and what I need to do to eliminate it. I have nothing connected to these ports at present.
Thanks, Bob, KN4HH
Thanks, Bob, KN4HH
Are these hold-over ports from a previous installation?
If so, they may not have gotten translated properly. You might need to delete them all, close CAT & SSDR, reboot, and recreate them. It doesn't take long. If that doesn't fix them, see Tim's excellent article about eliminating "Phantom" or "Ghost" COM Ports and Audio Channels.
Ken - NM9P0 -
Or you could Select Com4 for edit ( or add) and then right click in the edit (add) window to get advanced and then change com14 to com104. and save.
AL, K0VM
I tried your suggestion by deleting the com ports using SSDR CAT Remove command. No success with creating new ports. I then followed Tim's procedure for deleting phantom ports, of which there were several, and re-booted the computer and restarted SSDR. Now when I try to Add a port in CAT, I get a message "VSP failed to create". I suppose it wouldn't hurt to reinstall SSDR including VSP.
Bob, KN4HH
On the Flex Net yesterday, Dudley told someone to go to the Windows>Programs and Features> and Find FlexRadio Systems FlexVSP and right click on it and select "Repair" and let it rebuild FlexVSP. I would suggest a reboot before and after you do this.
See if that helps. If not, then you might need a total removal and reinstallation.
Ken - NM9P
Bob,
I had the same error when trying to creating ports. Discovered I had the old VSP driver 1.0.1 installed. This may be worth a check. You can see the version by using Windows control panel and the "uninstall or change a program" option.
Here is what I did that worked if you have the old version and I didn't have to reinstall all of SSDR.
Stopped all Flex related programs CAT, SSDR, DDUtil, etc
Use control panel to uninstall a program and remove VSP V1.0.1
Reboot the PC
Re-install just the driver, using this link since my PC is Win10 64 bit.
C:Program FilesFlexRadio SystemsSmartSDR v1.6.1764-bit DriversVSP
The new version is now 1.0.2
Started up CAT and added a port Com10 / 110
No errors, started up all of my Flex related software (DDUtil, SSDR, SDR-Bridge, CW skimmer)
and everything seems to work,
Then did a test on the new CAT port Com10 using the LOG option and tested using FA;. Freq date returned as expected.
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
6700 - HW.................... V 1.6.17.74
SSDR / DAX / CAT...... V 1.6.17.156
Win102 -
By the way, the reason I had the old version of the VSP driver is my habit is to install the new SSDR versions without "un-installing" the current one.
Per Tim E., at some point in the past there was a VSP update as part of an SSDR release. And the only way to get it was to un-install and re-install SSDR.
So it's worth a check to see if you have the old version V 1.0.1
Regards, Al / NN4ZZ
Win100 -
Thanks, guys. It was a combination of problems starting with old defined ports and old VSP driver. All is well now. I really appreciate all the helpful comments.
73, Bob, KN4HH
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
