1.6.17 after upgrade NO power output DM780
Ian1
Could use some help
After initially installing 1.6.17 I found the DM780 No power output error Radio Keys fine but just no output.
Decided I would let you guys figure out the issues and reverted back to 1.5 which worked fine for a few days. However today version 1.5 stopped transmitting as well.
I thought I would now update back to 1.6.17 and try and debug the CAT or DAX issue. So Far no luck. The 6700 keys and unkeys fine there is just no power output. I can force some power output by default or my microphone mode rather then my digital mode.
has anybody that has this issue been able to resolve it?
I updated DM780 to version 6.3..466 latest as of Dec, 17 2015.
Ian
Ian
Make sure DAX is turned on and the channels as well. Then make sure the levels are appropriate. Lastly make sure you have the right DAX audio channel entered into your DM780. Mines all good with 1.6 Mike N9DFD0
DAX Transmit is turned on and shows streaming as I stated the Flex will go into Transmit mode the receive mode is working properly.
Regarding the DAX Audio channel thank you for that suggestion because it solved the problem.
It appears that the new DAX setup changed the setting in DM780 and was transmitting the signal to another source.
Perhaps this is where others have been having the issue as well.
Ian
Ian, please look at your soundcard settings in DM780, they have to be changed for TX:
73, Alex DH2ID
There can be several reason why you are not transmitting signal if everything else looks correct (the red TX indicator in the bottom right is illuminated).
1.) Your emission frequency (audio tone frequency) is outside of the transmit filter. Example: if you audio tone is @ 500 Hz and your RX filter width is 1000-2000 Hz, you will not transmit anything.
2.) The DAX audio channel is not enabled on SmartSDR and/or on the DAX control panel.
3.) The digital mode program is not sending audio to the DAX TX channel (configuration issue)
- 653 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
