FRStack 1.6.4 for SmartSDR 1.6.17 - adds a Meter Window, Scanning improvements and more
Mark_W3II
Member ✭✭✭
FRStack 1.6.4 Updates and Additions:
SmartSDR / Flex SDK V1.6 Support
Meter Window - Voltage, PA Temp, TX Power Out / Reflected and SWR
Slice WNB Control
MIC Profile Tab
Squelch (Meter Level Mute) - Slice Mute enable option
Squelch (Meter Level Mute) - DAX assignment follows Mute option; A=1,B=2,etc.
Squelch (Meter Level Mute) & Scanning now work together
Main window Tab selection Option
Mini Window selectable Always-On-Top feature
Remote MOX Switch now supports CTS & DSR with Pin level; Added debounce logic
Scan Tab - Band Label now a Start Scan button
Scan Tab - Memory button click stops scanning then sets scan slice to memory
Scan Tab - added Skip Memory option
Link to the download page for FRStack
http://www.mkcmsoftware.com/flex
Note: Make sure you are running SmartSDR 1.6 before upgrading to FRStack 1.6.
The original FRStack postings:
FRStack 1.4.7 adds Scanning, Band Edge Beep, Band Use Label, SSB Meter Level Mute, Remote Hand or Foot Switch
https://community.flexradio.com/flexradio/topics/frstack-1-4-7-adds-scanning-band-edge-beep-band-use...
Global Hotkeys for common SmartSDR operations in FRStack
https://community.flexradio.com/flexradio/topics/global-hotkeys-for-common-smartsdr-operations-in-fr...
Memories and Most Recently Used Frequency Utility
https://community.flexradio.com/flexradio/topics/memories-and-most-recently-used-frequency-utility
Slice WNB Control
MIC Profile Tab
5
For scanning and recording using Audacity this is great... Play with the Squelch set the DAX trigger and the VOX in Audacity and it's very smooth. Built in hang time on the scan is a big help when waiting for the reply.
Thanks Mark
Dan -- KC4GO
Great!!! Thanks Mark!0
Hi Mark, i think it will be very suitable if you add in the new version - "Global Profile Macro" where possible to select not only Global profile but start an external applications as before profile intiiated and after initiation of profile. It will be good Smart Management for operation modes0
Mark, FRStack is great and the meter window is a very useful addidition.
Can you make it transparent with white fonts and not so widely spaced? This way
it would integrate better into SmartSDR. Could be made optional...
BTW you and the other SSDR API programmers out there are doing a
great job and a most useful service to us all !
I use FRStack to tune with my keypad, to use memories much easier than
with the original SSDR memory tab and to monitor my Flex-6500. Other
great programs are Mark's CMDmicro and the W2RF SDR-Bridge.
Thanks and 73, Alex DH2ID
Nice upgrade Mark, Thanks0
Mark has published the new version 1.6.5.0 of FRStack:
http://www.mkcmsoftware.com/Flex/Index
with a transparent meter window, which integrates beautifully into SmartSDR
Another highlight is FRStack's ability to update automatically.
Thank you, Mark, awesome!0
- 653 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
