CAT bug in 1.6.17
Drax
Drax Member
edited February 2019 in FLEX-6000 Signature Series
In addition to CAT I also have a SignaLink USB connected to my computer for another radio.  Even though the SignaLink is VOX PTT activated and doesn't use a COM port somehow CAT 1.6.17 keys both the SignaLink and the Flex PTT at the same time.  To avoid this I had to turn off the all of the Auto Switch TX Slice options for all the COM ports in CAT.
  • George KF2T
    George KF2T Member ✭✭✭
    Is your application set up to use CAT as the PTT method?
  • Drax
    Drax Member
    edited January 2016
    No.  WSJT-X is set to use COM port PTT.  The SignaLink even has it own built in sound device which is mentioned no where in my settings.  Not sure how it could be keyed by CAT.  There's no ghost com ports either.
  • George KF2T
    edited December 2016
    Try setting it to VOX.
  • Drax
    Drax Member
    edited January 2016
    Hexadecimal with it.  I changed WSJT over to use CAT and TS-2000 as the rig type and got it to work right.  (from the video https://www.youtube.com/watch?v=fV0kDWdFswc)    I couldn't get WSJT to use Flex 6xxx as the rig type.  That's why I was using COM port PTT to begin with.
  • George KF2T
    ha! i feel your pain, Drax. the 6000 emulation is not supported, yet. Think it's a hamlib issue.
