Flex with Log4OM and Winkeyer?
Doug Hall
With the new Winkeyer emulation available in 1.6 I configured Log4OM to use it. No issues there, but when I send a macro or type from the keyboard there is a small delay before CW starts sending. I haven't measured it, but I'd say it's on the order or 300 to 500 mS. I've confirmed that I have the lead-in delay in Log4OM's Winkeyer config set to 0.
Anyone else out there seeing this? And is anyone using Log4OM and a real Winkeyer? If so do you see any delay before CW starts going out?
Enjoying the new release!
Doug K4DSP
Doug K4DSP
I'm using WinWarbler and I don't have that problem.
Lew
N4CO0 -
Prova QUESTE impostazioni e dimmi se io ho Migliora Trovato miglioramento
I have had it happen a few times, but only on the first transmission after starting my logbook. After that it is fine. Using ACLog...1
Mysterious. I was getting variable delays at start - at one point it was nearly 1 second. I exited Log4OM and restarted the app and now it seems OK. Or at least consistent. I perceive a slight delay, maybe on the order of a tenth of a second, but it's usable.
Thanks for the help and suggestions.
Doug K4DSP
@Doug, I have seen similar behavior in log4om. I've been using it for several months now and after a couple of days running it becomes slow, allocates a lot of memory and takes a bit too long to make band changes when a click on a spot. There is some work to be done with that log program. It has a lot of features a like but it needs to be optimized. A version that works with TCP instead of omnirig would be great too.0
Doug, do have your log4om v2 settings for the winkeyer configuration for me?
Thanks in advance,
73‘, Stefan
Sorry, Stefan, I don't. I no longer own the Flex 6300 that I had several years ago.
Doug K4DSP
- 379 Community Topics
- 119 SmartSDR+
- 193 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
