error displaying for com 4
Mike Kasrich
Today I received my 6500 and Ive installed v1.6.17. In the SmartSDR CAT box I see "error" displayed. I don't see Com4 on my computer anywhere just Com1. Do I need to remove com4 and reinstall? I hate to remove anything for fear it will disappear forever.
As an added question if I try to add a com port should I see a selection to choose from? When I try to add I only see Com 4 as a choice.0
Well it doesn't seem I am able to create com ports. I'm not sure what to do.0
The error I get is "The Virtual Serial Port (VSP) failed to create. Double check the serial port settings.0
Well I obviously have something royally hosed up. Com 4 is showing up under other devices. Something 'taint right.0
Mike,
You might want to take a look at this post. I discovered an old version of FlexVSP was causing a similar problem. I detailed my solution down in the thread.
https://community.flexradio.com/flexradio/topics/smart-cat-1-6-17-com-port-problems
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
6700 - HW.................... V 1.6.17.74
SSDR / DAX / CAT...... V 1.6.17.156
Win100 -
Yep thought all that had been removed. Now things are working as I would expect.0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
