Making a cable for a WinKeyerUSB
N6WT Kent
I would like to make a cable for my WinKeyerUSB to connect to the ACC port of my 6500. My question is do I need to attach the ring connector of the RCA plug to a ground on the 6500?? I will be using a Winford Breakout Board for the ACC connector.
What WinkeyerUSB output are you connecting to the 6500?0
I don't think you should connect the ring to a ground at all. If connected to anything, it should be to a PTT input. That way, the WinKeyer USB can control PTT and you can key the Flex without setting BreakIn. I built my own 1/8" TRS (WinKeyer) to DB15 cable (Flex AUX input). I don't have the DB15 pinout in front of me, but the tip went to CW input, the ring to PTT input and sleeve to ground. It worked on both the 6300 and 6700 (I upgraded).
Kent,
By ring connector of an RCA plug do you mean the shield? If so, then the answer is "yes".
I have my WinKeyerUSB connected to my FLEX-6700 as follows:- Center pin of RCA connector to pin 4 on ACC connector.
- Shield of RCA connector to pin 5 of ACC connector. (You may use pin 5, 6, 7, 8, or 10 of the ACC connector, they are all connected to chassis ground.)
73, Ray, K9DUR
I think I mis-spoke. My cable was for a WK Lite, not the WinKeyerUSB. The Lite has a single TRS jack with TIP - CW, RING - PTT, SHIELD - GROUND. I also have a WinKeyerUSB which does have RCA jacks.0
There is a PDF document on the Flex website about using A WinKeyerUSB with N1MM+. It has a diagram showing the PTT and Key jacks on the WinKeyerUSB being connected to pins 4 and 14 on the radio. Is this not the case? Still should the ring or outer connection (shield) on the RCA plug be connected to a ground pin on the radio.0
- 318 Community Topics
- 575 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 157 SmartSDR for Maestro and M models
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 124 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 848 Genius Products
- 437 Power Genius XL Amplifier
- 298 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 132 Contesting
- 699 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 923 Third-Party Software
