SSDR V1.6 New Issue with USB Serial Converters
Cal Spreitzer - N3CAL
USB Serial Converters No Longer Work Since SSDR 1.6 Install. First issue noticed was DDUTIL V3.2.2.05 no longer would control my KPA-500 and KAT-500. My Com Ports for the KPA-500, KAT-500 and also my Rotor are no longer there after install of SSDR 1.6. See device status of USB Serial Converters listed below:
Microsoft Windows 10 reports a recent hardware or software change might have installed a file that is signed incorrectly or damaged....
The three missing com ports were Com21, 23, 27
This issue was not there prior to install. Please advise??
Cal/N3CAL
Cal/N3CAL
If you are referring to Shared virtual com ports, they are no longer support in SmartSDR CAT v1.6. A third-party virtual serial port software package that supports a null modem connection will be required for use with DDUtil.0
That's big news... Are you saying we can no longer use DDUTIL to control an amp? What does Smart SDR CAT have to do with three com ports on my computer.? Prior to SSDR 1.6 I had three USB to serial com ports on my computer, one was for the KPA-500 AMP, another for the KAT-500 auto tuner, and a third for a Rotor. They never were shared with SSDR Cat. SSDR 1.6 has caused them to no longer work!
This still isn't clear to me. Please advise further??? Thanks...
Cal/N3CAL0 -
Cal,
I can't address your problem directly, but can say that USB ports on my PC do control may KPA/KAT correctly with 1.6.17 and Win10-64).. I would guess that maybe SSDR CAT might have overlaid its com ports with exisiting hardware ports. Look through your device manager for port conflicts ( including hiddenports)
AL, K0VM
Wait for Tim W4ME to further explain. I know what he is on about, but don't have a super quick way to explain it. It is a a SmartSDR CAT improvement that changes how you set up your ports.
Steve K9ZW1 -
Al thanks for the reply, I had no hidden ports or any conflicts with port numbers. It looks like SSDR 1.6 install somehow removed my USB ports and showed a driver issue under USB Serial Bus Controller section?? I went back and uninstalled the USB serial converter drivers. Then had to manually re-install them. They now seem to be okay and DDUTIL is working with my AMP, Tuner and Rotor now.
Cal/N3CAL0 -
The FlexControl uses an FTDI chipset and I suspect when we uninstalled it for the upgrade it effected your USB serial ports.
Since I no longer contest, it seems 1.6 is not for me.
@Dave Don't give up so easily There are lots of non contest oriented improvements in 1.6.17.0
This is a big issue it effected me as well. I went back to 1.51 and am happy I did.
Going back to 1.51 is a problem as well took me several hours to get PTT working correctly again.
Ian
I no longer contest either
Like?
How about a contest filter?
uninstalthe USB serial converter drivers. Then manually re-install them.0
This is a very typical problem. My good old 2013 FTDI USB serial port drivers get replaced as a result of new software install and Windows brain-dead brilliance forces replacement of the FTDI driver on all USB serial ports and the newer "better" FTDI driver breaks the pre-existing FTDI ports.1
But how long will it be before we are told "we no longer support 1,51, you need to upgrade"?0
Not to be piling on but...that is another reason I don't like Windows. Do I understand this correctly, the 1.6.17 install touched previously configured things it didn't own?1
Do you not sleep Howard?1
I, obviously, cannot speak for FRS, but I believe one could make the stmt with 1.6 out they already stopped supporting 1.5. Independent of answering questions, they most likely will not be producing fixes against 1.5. This, in contrast to, continuing to support 1.x release after 2.x is out. 1.6 is a 'point' release in the 1.x series. The arrow moves forward not backwards. 1.x, i n contrast, is a major release, as will be 2.x.1
The, related, question I have is will problems identified in 1.6.17 be resolved in 1.6 or will they be fixed in 2.x, requiring people to pay for the fixes, by purchasing 2.x?1
It didn't for me but I've had this issue in the past, specifically when I installed a Microham Microkeyer - I had to go back and deal with pita Windows not wanting to reinstall the old FTDI drivers but I eventually prevailed. This issue did NOT come up for me in the v1.6 SSDR install - it left my old FTDI drivers in place.0
Part of our rationale for working to optimize the radio for contesting is the belief that the radio will improve greatly for all types of operators as we work on contesting -- since contesters are some of the most demanding operators for both performance and workflow capabilities, what we accomplish for contesters will benefit others as well.
3 -
He does, but at night where he is travelling. Remember he is our wanderer!
I chose to install a multi-serial port card rather than doing USB-Serial converters, based on past woes with even very high end USB-Serial device drivers.
Steve K9ZW
I would normally agree with that except for a comment Steve made that sounded remarkably like after they release 1.6, which they just did, they would pivot to full steam ahead on 2.x in earnest. I took that to mean 1.6 was it. This was in the context of a 'final' 1.x release JUST dealing with the known 1.x bugs, no enhancements, no features, no squelch, just clean up. Whether that is 1.6.18 or 1.7 is irrelevant to me. I would go for the former as there would be no additional features warranting a change to the release number (Version.release.modification). But, nobody there has asked me.1
- 318 Community Topics
- 575 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 156 SmartSDR for Maestro and M models
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 122 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 847 Genius Products
- 298 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 132 Contesting
- 696 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 921 Third-Party Software
