SDRMemory6K and SDR Monitor does not connect to radio, but SWRPlotter6K does.
K9DUR's program SWRPlotter6K connects to my Flex 6500, but his SDRMemort6K and SDRMonitor programs do not.  The "CONNECT" button is grayed out, like it does not see the Flex 6500 on the network.  Has anyone seen this and have a solution?
Charles K5UA
Welcome!
  • Member ✭✭
    edited July 2018
    Ray would be the main to discuss this however I would try uninstalling and reinstalling the Memory and monitor programs.  Reboot after you uninstall and before you reinstall.
  • Member ✭✭
    edited January 2016
    Thanks Neal, will try that.
    Charles   K5UA
  • Member ✭✭
    edited March 2018
    SDR Memory works here, don't have the other one.
    Dan -- KC4GO
  • Member ✭✭
    edited July 2018
    What version are you using Dan? Ver 3.2 does not work here.
  • Member ✭✭
    edited March 2018
    V 3.2.0
  • Member ✭✭
    edited July 2018
    Thanks Dan, then it must be something local on my system that keeps it from running.
