Looking for Amplifier for working with my Flex 6300: suggestions are welcome!
13»
  • Don Stefanik
    Don Stefanik Member
    edited June 2017
    I have an ALS600 that I run with my 756 Pro3. I am getting the Flex 6300 and am wondering what cable will I need to run the amp with the flex? Is it the same type of remote control cable I need. I also have the Ameritron ARB-704.
    VA3KBC
  • Ross - K9COX
    Ross - K9COX Member ✭✭
    edited January 2016
    I have the same setup here, just use the same cable. The ARB-704 is not required however if you have it go ahead and use it, I don't and have no issues.
  • Cal Spreitzer - N3CAL
    edited January 2016
    I also use the Elecraft KPA500/KAT500.  Very effortless and forgiving.
  • Don Stefanik
    Don Stefanik Member
    edited January 2016
    Many thanks!!
    VA3KBC
