SSTV with the Flex Radio 6700
Nicholas Parry
Hi
Can anyone recommend a SSTV decoding software package that integrates easily with the SmartSDR for the Flex 6700? I am using HDR for PSK31 so maybe there is a plugin for SSTV?
Thanks and Merry Christmas to all, 73's , M0NAG
I use MMSSTV with my 6700. It was fairly easy to set up. The program is free. You can find it here: http://hamsoft.ca/pages/mmsstv.php
If you really want to see some great photo's, I would highly recommend EasyPal. It will give you digital pictures in HD. You can use DAX for the transmit and receive functions. Just put EasyPal into your search engine for download.0
I have used both MMSSTV and EasyPAL.
MMSSTV sends standard analog SSTV using DAX Channels as you would a sound card. It is fairly easy to set up and works well,
EasyPAL sends digital format pictures and file transfers. Pretty slick! It also has a "hybrid mode" that sends a URL Link to a place on the internet that downloads the picture. It is neat, and fast, but you aren't really sending the picture, only a computer address.
These two seem to be pretty much the standard that I have encountered, though I haven't done a lot lately - I have gotten into too many other things in the hobby lately.
Ken - NM9P1 -
MMSSTV or Multipsk offer the most SSTV modes for standard operations, then Easypal for digital transfers. . I assume that when you say you use "HRD" for PSK31, you mean you are using DM780 for SSTV and HRD for PTT. Setting up MMSSTV or Multipsk is essentially the same. You would configure audio paths for DAX.
Andy K3UK
Thanks for the answer, it all very helpful information. Once the children's toys are out of the way I can start playing with my new toy, Flex 6700. If I using a com 5 port with HRD would I need to create a new com port for an sstv software? I guess this would only be nessary if I wanted to use HDR and MMSSTV simultaneously? Kind regards, m0nag0
Personally, I have found it best to have a separate COM port for each program. Enjoy the toy. Merry Christmas.0
If you are using HRD the digital data program DM780 that is part of HRD has a very capable sstv rx and tx, look along the row of options at top DM780 at around 7th option you should see sstv, click on the sstv option, when the selection box appears click on DISPLAY not MMSTV and the SSTV decode encode screen appears. It is very user friendly.
Best regards, Neil, M0WNF
Are you currently running easypal? Which radio do you have. I used to run easypal into a TENTEC Orion with good results.With the .6300 the power meter and swr meter are very erratic. Signal looks fine on the screen. Don"t know i"m getting out and what condition. Receive is great.0
i Just can't seem to get it setup to work on my 6700
If you can not see Flex TX and RX option in EasyPal.
If you open EasyPal, then open Windows "Sound Mixer Options" and scroll down to Apps list. Select the drop-down to the right of EasyPal, select the correct TX and RX devices, they will be set to default. You may see another entry once you start the process in the Mixer for EasyPal, just set it as well. Now close and reopen EasyPal, and you will see the option you want at the top of the list.
W0TTP - Scott0
- 388 Community Topics
- 156 SmartSDR+
- 52 Aurora
- 970 Maestro
- 944 Genius Products
