mike audio out from DAX?
Ken - NM9P
Ken - NM9P Member ✭✭✭
I have been loving my 6500 for over two years, but haven't found a solution for this one...
I would love to get my USB Mixer out of the audio chain and go directly into the 6500.  BUT, I need to be able to record my mike audio for other purposes using Audacity.  (It is handy when recording voice keyer files preparing for a contest, too.)
Is there any way to get either processed or unprocessed mike audio OUT of the 6000 series via a DAX channel so I can record it?  If there is, I haven't found it.
I can send receive audio out to audacity, but not Mike audio.
Any ideas?
Ken - NM9P
  • Larry _ NY8T
    Larry _ NY8T Member ✭✭✭
    edited June 2020
    The only thing I can think of is using full duplex (record via dax from the receive slice) but that's not practical during normal or high power operating.
  • Jay Nation
    Jay Nation Member ✭✭
    edited June 2020
    Ken
    I'm not expecting this idea to be a solution, but could you use a hardware mic mixer, with the outputs split to line-in on the PC, and line-in on radio?
    73, Jay - NO5J
  • Mark_WS7M
    Mark_WS7M Member ✭✭✭
    edited December 2015
    What I'm not sure of is if your mic audio gets past the 6500 at all and even to DAX.
    I think Larry is on to it, that the only audio that is going to get to DAX from the radio is receive audio.  You could certainly record that I think.
  • K9DUR
    K9DUR Member ✭✭
    edited June 2020
    Ken,
    Simple -- set Audacity to use the DAX MIC channel for input.
    73, Ray, K9DUR
  • Ken - NM9P
    edited December 2016
    DAC MIC Channel?  I don't see this one.  (or are you tongue-and-cheek requesting such an output?)
    I have tried several DAX RX and TX Channels, using both virtual "cable ends"  (the regular and RESERVED ends) to no avail.
    But I was in a hurry and gave up because I already had recorded most of my voice keyer files.
  • Ken - NM9P
    That is what I am doing currently, using my Behringer Q802USB mixer.
    I have the mike into the mixer, then fed the mixer line out into the BAL port of the 6500.  I also used to send one of the AUX Sends to my 1500.
    But now that I have sold the 1500, I don't need the mixer to split the MIC audio three-ways.  If I could take mike audio from the rig, I could take the mixer out of the line.  (And perhaps unplug the mike from the rig and back into the mixer whenever I want to record my radio spots using my studio mike.)
  • Ken - NM9P
    I have done that while making audio adjustments, as per my tutorial videos.  But it records post-processed audio, which is good for testing my TX profiles.  But I would like to record pure pre-processed audio for use in my voice keyer, because the rig processes audio from my voice keyer (which is sent in via a DAX TX Channel) in exactly the same way it processes my mike audio.  If I record from FDX, then it gets "double-processed" and is quite sharp!  (I tried it)
  • K9DUR
    K9DUR Member ✭✭
    edited September 2016
    OOPS!!! I am afraid that I have inadvertently mentioned a feature that is not yet available.  Forget I said anything. -- 73, Ray, K9DUR
  • K9DUR
    K9DUR Member ✭✭
    Ken, Send me an e-mail to k9dur@arrl.net so I can send a private reply back to you. -- 73, Ray, K9DUR
  •   VE6KWA
    VE6KWA Member ✭✭
    edited July 2016
    Tim already eluded to the feature awhile back.
  • Roy Laufer
    Roy Laufer Member ✭✭
    When did Tim allude to this? (I have been urging this tweak for the past year) I'm hoping this new information isn't just a "tongue in cheek" joke. I would really love to be able to record both recieve and transmit without a lot of hardware kludges... Let's all just hold our breath for 1.6 and hope that it gets here before we're all unconscious from oxygen deprivation...
