10 Meter Contest! Sweet!
K2CM
I worked the 10 meter contest on CW this weekend! Lotsa QRM; but, was able to separate it out with the 50hz or 100hz filtering. It was fabulous!
I have to say the same thing. I managed 200+ contacts and 50,000 points. I stayed in S&P mode and having the panadapter is just amazing. I regularly marched up and down the band using both N1MM and my own notes to void signals I'd worked before.
When things got message as did a couple times with big signals right on top of each other I expanded the display so I could see both sigs and used filters to work the one I wanted.
For fun I connected up a standard display radio and tuned around and I found it hard to figure out what I wanted to do. I guess I've become addicted to the pan adapter!0
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 298 FLEX-8000 Signature Series
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
