ARRL 10m contest cw file
In my testing my CW message file got really corrupted. Anyone know where I can get a cw message file with the correct stuff for the 10m contest? I've been searching about but have not found one yet.
http://n1mmplus.hamdocs.com/tiki-list_file_gallery.php?galleryId=25 fourth from the top.0
Also I have found two ways to access these files
When you select a contest two tabs will be available for the contest 1. the contest tab and 2. the associated files tab
1. Contest tab: from here in the show setup box there will be at times a pathway to locate relevant .MC files
2. Associated files tab: I just found this in response to your post and that is the sample function keys link
Once you have all of your function keys defined for a specific contest then right click any of the function keys and select file in the upper left then select save these messages to a different function key .MC file name
As you probably already know, the next time you work this specific contest you will just have to go to it's associated file tab, select change for the appropriate function keys and load the file that you just named.
Hope that helps.
On a semi related point....is there some "trick" to get N1MM+ to send cw? I've tried any number of ports, winkey checked and unchecked and I cannot send cw via n1mm+0
What kind of cw keying device do you have interfaced to your computer?0
I just figured out technically none. Guess the SDR doesn't support n1mm+ totally at this point. I need to hook up a winkey to the radio.......learning curve.
I have not looked into it, but I think there is a way to interface n1mm w/ cwx w/o needing an external keyer. I like my wkusb so I have not looked into it but have seen quite a few threads here describing what needs to be done to accomplish this.0
I was using N1MM to key CW. Try this: http://kc.flexradio.com/KnowledgebaseArticle50119.aspx
N1MM+ can send strings to the CWX on the 600 series using CAT commands.
I am not in front of the rig right now, but someone posted some samples a while back about how to build your own message file.
THe problem I had was that it kept sending only 59 or 5N for signal strength using the imbedded macro link instead of 5NN. So I simply hard-programmed it to sent without using the imbedded link.
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
