6300 Flashing green led, will not power up
Hate to be redundant. My 6300 does the same thing, every time I begin from a cold start. Running Win 8.1/64, SSDR 1.5.1. I did deinstall of 1.5.1, downloaded a fresh installer and reinstalled 1.5.1 again. Not a big issue. Thanks in advance for the fix.0
Hi Guys, I just heard back from Dudley at the Help Desk, the issue has been fixed now. It will form part of the next update release....which I guess won't be too far ahead. 73 Richard MW0XDT2
I believe you may have misunderstood. We believe we know what is causing the issue, but a fix has not been verified yet. We are working on it.0
Sorry Tim, I had a further message from Dudley explaining it may be a little while before the fix is verified and available. Either way, I appreciate the work you and the team are putting in. Many thanks, Richard0
My 6500 did the same thing this morning, first time I have seen this, it was the coldest it's been
in the shack downstairs, just 61 F. It did boot successfully right after forcing it to shutdown.
For what it's worth, my 6700 does it also. After first applying power (via a recycled FLEX-5000 power cable), the green light flashes, and will do so until the sun drops off the main sequence (I left it for 12 hours just to see). Cycle power again, and it comes up fine. I'd classify this as an annoyance - not a huge deal - but it would be nice if it could be fixed. Otherwise, you can have my 6700 when you pry it from my cold, dead fingers.
73, Bob, WA4FOM
I also have experienced this flashing green led forever on boot sometimes; not always. a reboot cures it.0
I should mention that I never had that happen until I changed routers. I think there is a connection there but not sure.0
I don't remember precisely when mine started, but there were definitely no hardware changes leading up to it.
This issue you describe where the radio does not complete the boot up process and the power LED contines to blink green on an initial power up has been addressed and will be included in the next release of SmartSDR0
My 6300 at my cabin did it to me for the first time this morning. I have been up here for a week so everything is nice and warm. I understand it will be corrected in the next update (wow try and get that kind of service from Microsoft).
Can I just leave it on ? I am having knee problems and at home I do not like going down then up the stairs to my shack just to press the button on the flex so I can use it in my Man Cave in my pole barn. I have a little heated work room out there and it has became my second shack because I do not have to do the stairs.0 -
Yes, you can just leave it on.0
Tim - I'm seeing the same anomaly during startup of my 6700 w/GPSDO option. If I leave the radio shut down for a few hours with DC power still applied (to maintain the GPSDO) then about 50% of the time the 6700 will hang during the startup sequence -- just before my callsign would normally be displayed on the front panel, with green light flashing. Sometimes - but not always - pressing the power button to shut the radio back down, and pressing once again to restart the radio will clear it - but often as not it still hangs at the same place during startup.
If I cycle the DC power by switching off/on the power supply, the radio will start up normally every time.
One thing I've noticed is that my 6700 needs to be in a shut down state (with DC applied) for a few hours before the hang behavior will appear, or reappear after clearing it. I haven't attempted to narrow the time down yet, but it will not reoccur immediately after cycling the DC.
I've tried using two different power supplies (Astron & Icom) and a deep-cycle boat battery, all with no change in symptoms.
Mike - KB1MH
I just realized I wasn't holding the power button in during shutdown per Tim's earlier response. I'll try that next time and report back.
Mike - KB1MH
Thanks for the thread. Regarding my (several months old) 6300, the green light would blink on once when I turned on the power supply. Then press the green button again to start and no blinking. I would hear the click, then another click, but the green light would not come on, and radio would not be seen in the software. I disconnected the copper from the router. And disconnected the power pole connector from the radio. Rebooted the router, and the desktop. Started over again and radio started fine. Another year off my life hi hi. 73 KH6DAN
- 339 Community Topics
- 609 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 172 SmartSDR for Maestro and M models
- 405 SmartSDR for Mac
- 265 SmartSDR for iOS
- 248 SmartSDR CAT
- 186 DAX
- 373 SmartSDR API
- 9.2K Radios and Accessories
- 19 Aurora
- 196 FLEX-8000 Signature Series
- 916 Maestro
- 888 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 746 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 964 Third-Party Software
