Seem to be getting a bit of echo, not feed back something a little in the transmit audio with MMVARI
videorov
Not sure what might cause this. The rcv is all ok but transmit is a little stange sounding.
You are getting RF into the firewire cable. It is a fairly common problem with the 5000. Most of the time it can be cured using a shielded firewire cable0
I have some toroids arond it, snap on type the person I bought it from put them on there.
Wonder what I can do with it. Maybe wrap with foil and ground foil:)0 -
When I had my 5000 I found the torroids did not help. I had to use a shielded firewire cable0
Who sells them, the best I can buy? Maybe a music store on the net.0
It wasn't the cable but my settings in DigL. I was using LSB mode and not the DigL
mode and my settings where to high in the rcv.
Its working clean now. Just have a extra firewire cable now:)0
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
