FLEX-1500 on an Apple iMac
Sandi
Sandi Member
Hi there! I just won a FLEX-1500 SDR and I have a Apple iMac. The software that came with the radio is for PC. I want to know if I will be able to use this radio on my iMac.
  • Pat
    Pat Member
    edited April 2020
    unfortunetly i think no........
    73's
  • Mark_WS7M
    Mark_WS7M Member ✭✭✭
    edited December 2015
    You could try it under VMWare fusion with a windows guest.
    Parallels is the direct competitor to VMWare fusion.  I use fusion after having used both for many years.  The support at fusion is far superior in my opinion.
  • Reggie-k6xr
    Reggie-k6xr Member ✭✭
    edited July 2016
    Yes you can. I use a Mac-mini. but you need to install parallels so you can run windows on your mac. You can run OS-X and windows at the same time if you use one of the VM programs. I use Parallels and it work marvelously!
  • Scott - WM7C
    Scott - WM7C Member ✭✭
    VirtualBox works as well, but you do need a copy of Windows.  You can also install Windows on your Mac using Bootcamp and run Windows natively without virtualization.
  • Tim - W4TME
    edited March 2017
    We do not support PowerSDR running in a virtualized environment.  The added latency overhead plays havoc on the 1500 when transmitting.  For Mac hardware, running Bootcamp is the only viable option.
  • DrTeeth
    DrTeeth Member ✭✭
    edited December 2018
    Sandi, congratulations on your win! May it give you many hours of fun and enjoyment.
  • Sandi
    Sandi Member
    Thank you all for your replies. I really appreciate everything you all have sent. I think the best way for me to go is to let my husband put it on his PC. Of course with the understanding that I am just letting him borrow it for an extended period of time!
