Trying to get the VARI to work with my MMVARI rtty program
videorov
videorov Member
edited December 2015 in FLEX Series (Legacy) Radios
I have it receiving  but can't get it to transmit. I don't seem to be getting the audio from
the program over to the Flex 5000. If I turn on the VOX on the Flex it goes off when I
push the VARC button to receive rtty.
I must have something not right somewhere since I can't transmit the audio from
the MMVARI program.
Receives great so Im almost there:)
  • Andrew O'Brien
    Andrew O'Brien Member ✭✭✭
    It should work just like other digital mode software .  Do you have other digital mode software where the PTT is working and audio tones are transmitted by the Flex ?  Also, make sure the VAC icon in PowerSDR is active.
  • Andrew O'Brien
    See this video I just made.  Make sure the PTT check box is checked in the Radio Command area.
    http://www.youtube.com/watch?v=b6XsoMRqvHI&hd=1
  • videorov
    videorov Member
    I only have a one com port 1 in my device manger right now.
    No audio in your video but I watched it but Im still not able to transmit.
  • Andrew O'Brien
    There is audio, from the Flex.  What do you mean you have only ONE comm port ?  For an application like digital mode software to activate your PowerSDR software and switch the Flex in to TX mode when you press TRANSMIT (e.g. in MMVARI) , you need ONE port for PowerSDR and another port for the digital mode software.  Most people use virtual serial port software where you can "pair" the two ports.
  • videorov
    videorov Member
    Yes looks like I need to the VSPM program. I have it here from K5FR he sent me.
    That I guess is the control program to control the ports.
    Will have to learn how to use it:)
  • videorov
    videorov Member
    I have it working and yes I have the VSPM program to control the PTT line now.
    The Flex5000 is working great now for Digital modes. MMVARI is a great progam
    and have used it in the past on a TS2000. Its easy to use with its mem buffers.
