Elecraft MD2 "Heil Sound" Mic to Flex 1500
would like to wire up an adaptor to work with Flex 1500. The only button on the mic is the PTT. My understanding is the resister was added on the MD2 to increase auido level so it might not be necessary when connected to the Flex 1500.
The Elecraft MD2 pin out is: Flex 1500 pin out:
1=AF (5.6K resister to 5V) 1=N.C.
2=PTT 2=N.C.
3=N.C. 3=5V
4=N.C. 4=Mic(-) Mic ground?
5=N.C. 5=Mic (+)
6=5V 6=PTT
7=GND 7=Chassis Ground (PTT GND)
8=GND (PTT GND) 8=N.C
Would the correct wiring be?
MD2 Flex
1=AF (5.6K resister to 5V) 5=Mic (+)
2=PTT 6=PTT
6=5V 3=5V
8=GND (PTT GND) 7=Chassis Ground (PTT GND)
7=GND 4=Mic (-) Mic ground?
Im worried about the resister applying voltage to pin 5 on the Flex.
I would appreciate any input.
Regards,
Robert
KD7YDW
This is a condenser type mic so it needs the +5VDC bias on the mic+ line. You do not need the mic bias resister (it is already installed in the 1500 along with a filter cap) and jumper blocks installed, so the mic will need to be configured for a K3 not a K2. I think this will work, but no promises as I don't have one of these mics to try out.
Mic Connector to FLEX-1500
1 Mic audio, low-Z (~600 ohms) -> 1500 pin 5 (mic+)
2 PTT -> 1500 pin 6
3 DOWN button
4 UP button
5 FUNCTION button
6 8V (10 mA max) -> 1500 pin 5
7 Ground -> 1500 pin 4
8 Ground -> 1500 pin 7
You have mic pin 6 (8v) going to 1500 pin 5 (mic+). Did you mean to have mic pin 6 (8v) going to 1500 pin 3 (5V)?0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
