Youtube video for fldigi and flex
Michael Coslo
Hey all
As promised, I have created and uploaded a video on getting fldigi and FlexRadio signature series radios to play nice with each other.
You can find this on my Youtube channel at:
https://youtu.be/IVOhj244e30
The Youtube channel is called Divide by Zero Productions, and I will perhaps have more videos as time goes on.
Perhaps even the dreaded Windows 10 soundcard driver issue……….
- 73 Mike N3LI-
- 73 Mike N3LI-
Mike,
Excellent video and audio. Great information. The production is top notch.
"Divide by Zero" is the best title!!
Thank you.
jim0 -
Thanks for the video. Have you been able to get FLDIGI to transmit CW?0
Great demonstration!
Thank you very much.
I've used a CW QSK signal on right channel on the Right Channel tab of the configuration menu.0
Hi Mark - another update on CW fldigi and Flex.
I find that I must increase the audio level in DAX to get a decent decode in fldigi. Much higher than I need for any other modes. The green signal strangth bar at the right hand side of the fldigi window hardly registers on CW otherwise. Definitely an fldigi issue. I'm going to consult with Dave W1HKJ to see if this is a known issue. It isn't a huge problem, but a bit of a nuisance.
How does the QSK signal work? Do you have to use external hardware? Is the Flex in CW mode or is FLDIGI generating tones?0
Nice job illustrating the process of seting up.0
This is a tone generation method for CW. No external equipment needed.0
- 325 Community Topics
- 578 The Flea Market
- 7.7K Software
- 6.2K SmartSDR for Windows
- 386 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 365 SmartSDR API
- 9K Radios and Accessories
- 126 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 849 Genius Products
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 701 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
