Serial PTT input for remote operation ...
Marc Lalonde
i just wake-up and realize that in smart cat it only have PTT output
whit RTS or DTR output to radio ...
for remote operation it may nice to have input on CTS or DRS or even CD Pin
so permit to use a "local" PTT switch ( a simple pull-up on CTS and vola !! )
and not think it big deal to implement that in software
ok it still possible to create virtual serial and make it, but better to have it strait on Smart CAT
This feature already exists in FRStack.
Go to www.mkcmsoftware.com then click the FRStack link.
The documentation for FRStack explains what you need to do.
Mark AA3RK
Thank Mark
Mark you have do a great job on your software but
usually i try to not rely on third party software as much as possible
have already to much software running on my work PC ;-)
the good news is that i already build my USB PTT switch
FTDI cable or board was nice and easy ....
Marc VE2OLM
Do you have any more info to share regarding your remote PTT switch build? I've very interested in building one, because I am primarily a foot switch and boom mic operator for contests. This is the one missing feature for remote operations, that I really need.0
HI
FTDI USB to UART cable
http://www.digikey.com/product-detail/en/TTL-232R-5V-WE/768-1029-ND/2003494
then a 10K resistor between RED and Brown Wire (may 1K to 100K it not really care)
put BROWN wire to GND ( Black wire) to TX
for test it https://sites.google.com/site/terminalbpp/
normally when PTT presed the" CTS" button go Green ;-)
73 Marc VE2OLM1 -
Fantastic, thanks Marc!
73, Robert W6RWC
That the schematic but please note that Mark - AA3RK software support only
DSR pin that not available on FTDI cable ,so still no magic solution
Marc,
The solution that FRStack currently offers is identical with the exception I used a USB to RS232 and chose the DSR pin. With that said using a USB to FTDI and the CTS is a minor change to FRStack.
FRStack provide a large number of features that enhances the Flex experience.
Are you interested in testing and using FRStack if this change was made?
If yes, please contact me via my email address listed on www.mkcmsoftware.com so I can work with to test this change.
If not, I will add this option to a future release of FRStack once I obtain a USB to FTDI device.
Mark
Is the USB to FTDI device ready?0
- 383 Community Topics
- 638 The Flea Market
- 144 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 57 FlexControl
- 934 Genius Products
- 342 Tuner Genius XL
- 303 Shack Infrastructure
- 141 Amateur Radio Interests
