Using a UHD tv as a computer monitor
N4AB
N4AB Member ✭✭
I just bought a Vizio M43-C1 UHD TV for the house but before using it for TV watching I tried to use it on my radio desktop computer as a monitor. Works fine as in HD (1080) mode however, I can't figure out how to set the computer up to drive the TV monitor to anything except 1920 x 1080 (or lower). Checking the screen resolution on Window 8.1 only shows that 1920 x 1080 is the recommended setting. I am using a HP desktop, I7-4770K quad core with a Nivda GeForce GTX 745 Graphics video card and using a HDMI cable. Do I (or can I) set some thing (hardware or software) on the video card, the computer, the TV or some settings in WIN 8.1. Not much of a modern computer Geek so I need some help. Al, N4AB
  • George KF2T
    George KF2T Member ✭✭✭
    edited February 2019
    I suspect that 1080 will be your maximum real resolution using a TV monitor. Not sure what provisions your computer has for 4k, or if the monitor really supports it.
  • Jon_KF2E
    Jon_KF2E Member ✭✭✭
    edited July 2018
    Al,
    Check out this article for some info on what you are trying to do...
    http://www.tmproductions.com/50-uhd-tv-as-a-desktop-computer-montior/
    Jon...kf2e
  • Bob G   W1GLV
    Bob G W1GLV Member ✭✭
    edited June 2020
    Al, if you right click on the screen you will get a choice for screen resolution. See what that gives you.
  • N4AB
    N4AB Member ✭✭
    edited August 2018
    Bob, I already tried that, but the MAX resolution that is displayed is 1920 x 1080 I need to get the system to recognize that the display is a 3840 x 2160 display. If that is what it really is. Getting help from Vizio is not going well. Thanks for the suggestion. 73 Al, N4AB
  • EA4GLI
    EA4GLI Member ✭✭✭
    edited February 2017
    It could be the cable. You either need to use display port or hdmi2 or dvi to go beyond 1080.
  • EA4GLI
    EA4GLI Member ✭✭✭
    edited November 2016
    Looks awesome!!
  • Al K0VM
    Al K0VM Member ✭✭✭
    edited November 2017
    AL,
      It may also be dependent on your graphics adapter...  Does it support a higher resolution ?
    Iniitailly I had the same problem but I was able to go into the Nvidia adapter control panel and add a customized resolution (2560x1440)...  But their warnings included faulty selections MAY cause damage..
    YMMV
    AL, K0VM
  • K6OZY
    K6OZY Member ✭✭✭
    edited June 2015
    DVI will not do 4K.  You need DisplayPort or HDMI2 to do 4K 60Hz
  • K6OZY
    K6OZY Member ✭✭✭
    According to this review:
    http://www.rtings.com/reviews/tv/lcd-led/vizio/m-series-2015
    The TV is best used on HDMI5 with "Game Low Latency" enabled.
    The TV will not do Chroma SubSampling 4:4:4 at 30 or 60 Hz, so this thing will be a blurry mess in 4K on a PC.  This goes to exactly what I was saying above about not all TV's being equal.
    Many comments at the bottom say HDMI5 can do 60 Hz, but because its not 4:4:4, colors will be messy.   For those wondering why that is so important, read this article:
    http://www.avsforum.com/forum/166-lcd-flat-panel-displays/1381724-official-4-4-4-chroma-subsampling-...
    Nvidia's website says that video card can only do 4K over Display port:
    http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-745-oem/specifications
    "3840x2160 at 30Hz or 4096x2160 at 24Hz supported over HDMI. 4096x2160 (including 3840x2160) at 60Hz supported over Displayport. Support for 4k tiled MST displays requires 326.19 driver or later."
    This means you need a Displayport to HDMI cable.  I cannot guarantee that the cable will support HDMI2 as I have never tried it.   You may have to try it and find out:
    http://www.amazon.com/Cable-Matters®-Gold-Plated-DisplayPort/dp/B004C9P9TM/ref=sr_1_1?ie=UTF8&qi...
    I hope the helps!
  • O.S S.O.
    O.S S.O. Member
    edited November 2015
    To  K6OZY, Elmer:
    Confused: first you stated that TV is glorious and we are talking here about TV as monitors. Later you stated that all processing make screen bad for computer use.
    So what steps are required in order to make Samsung TV valuable option as computer monitor?
    Is it just turning ON PC mode?
  • Larry - WA7LZO
    Larry - WA7LZO Member ✭✭
    edited May 2017
    To achieve true native UHD support, you may want to use an appropriate high end graphics card, along with a purpose built UHD PC monitor, such as the Samsung 32 inch UHD monitor.
  • O.S S.O.
    O.S S.O. Member
    Don't you find that icons/text on 32 inch monitor are very small when you work in at least 3440 by 1440 or even 3820 by 2160? The TV set with such native resolution (40 inch) offer 110 PPI and much more comfortable working environment especially for your eyes. I am talking about real PC usage (not games)
  • K6OZY
    K6OZY Member ✭✭✭
    You must turn on PC mode and purchase a screen that has 4:4:4 Chroma Subsampling and HDMI 2.0 for 3840x2160 60 hz.  The Samsung I mention above does, most cheaper models do not.
  • K6OZY
    K6OZY Member ✭✭✭
    A 32 inch screen is too small to use a UHD display at native DPI scaling.   Most modern OS's perform a DPI scaling technique to make the GUI elements larger.   Unfortunately, that also scales SmartSDR and then you aren't really gaining anything. This is why I picked a 48 Inch screen.  It maintains ~100 PPI that we are used to using on most screens.
  • K6OZY
    K6OZY Member ✭✭✭
    I highly recommend this website for quickly calculating PPI for devices that you use.  Then try to purchase additional equipment that is close to the same PPI if you do not wish to use DPI Scaling in the OS (Which I hate in Windows).
    https://www.sven.de/dpi/
  • G
    G Member
    edited January 2016
    I just bought the same model after spending quite some time online making sure to make the right choice. Your answer was actually taken into account so... Thanks! excellent choice. I'm using my laptop for gaming; do you have any recommendations in regards to the best settings on the TV for computer gaming ? I looked online a lot and cant find anything satisfying. Sharing your settings would be a massive help
  • Top Dawg
    Top Dawg Member ✭✭
    edited January 2016
    Where do you find the info about Chroma Subsampling for any particular set? Some online stores offer very little in the way of specs.
  • K6OZY
    K6OZY Member ✭✭✭
    edited January 2016
    I'm glad it helped.  I liked the TV so much, I picked up a second 55" version to replace my main screen.  So now I have a 4K UN55JU7500 on the left and the UN48JU7500 on the right.
    First thing you must do is change the input name to PC.  To do this, hit source on the remote, highlight the input you are using on your PC, hit the down arrow.  Pick “Edit Device Type” and then set it to PC.  This is crucial as it enables PC mode.
    Next go into the normal Menu and enable the following:
    System -> Eco Solution , Set everything to Off
    Picture:
    Picture mode: standard
    Backlight 20
    Contrast 100
    Brightness 50
    Sharpness 50
    Picture Size: 16:9
    Picture Options:
    Color Tone: Warm1
    HDMI Black Level: Auto
    HDMI UHD Color: On (select the input being used as a PC)
    As long as you are using an HDMI 2.0 connection, hooked up to an nvidia GTX 700 series or newer, you can pick 3840x2160 @ 60Hz.
    Enjoy!  I love them.
  • K6OZY
    K6OZY Member ✭✭✭
    edited January 2016
    Robert, I google a ton knowing its a requirement, but I really love AVS Forum and this site:
    http://www.rtings.com/tv/reviews/by-usage/pc-monitor/best
    UHD ( Chroma Subsampling 4:4:4) is listed as a column on this page.
  • EA4GLI
    EA4GLI Member ✭✭✭
    Great site. This is very valuable information. Thank you Chris.
  • EA4GLI
    EA4GLI Member ✭✭✭
    This is a great thread if anyone is interested in 4k at the radio shack. I jsut though I would bump it and add some additional info.
    I just came across this adapter which is great
    http://club-3d.com/index.php/products/reader.en/product/displayport-12-to-hdmi-20-uhd-active-adapter...
    This is a DisplayPort 1.2 to HDMI 2.0 adapter so you can actually use an older video card instead of having to buy one of the new NVIDIA GTX 750 Ti, 960, 970, 980 and TitanZ.
    The adapter will do chroma subsampling 4:4:4
    I have a NVIDIA GTX 670 that can drive a display up to 4096x2160 only over DisplayPort and with that adapter I can use that card with a 4K TV.
