K6TU Control for iPad Application
Andy F5VAI
This is more of a tip for other users of Stu's K6TU new iPad app. First of all it works brilliantly and gives me full remote capability anywhere in my house.
The only problem I found was that the received slice was a bit choppy, almost as if my iPad Air was just not up to the mark. After doing quite a few checks thinking it was a Wi-Fi problem, I found the culprit. It was that I had the Bluetooth switched on in the iPad, even though nothing was connected to it.
Now it works superbly. Stu and others are certainly to be congratulated on producing an app that rivals the Maestro.
Andy,
Thanks for the kind words and the feedback about BlueTooth. I'm curious which band and channel is in use by your WiFi. I'm guessing it is 2.4 GHz given the Bluetooth interference - can you confirm and then also say which channel you are using?
Thanks!
Stu K6TU0
- 390 Community Topics
- 662 The Flea Market
- 440 SmartSDR for Mac
- 55 Aurora
- 971 Maestro
- 946 Genius Products
- 308 Shack Infrastructure
- 216 Networking
