6300 and AM broadcast band
I was trying to listen to the local AM station on 1400 Khz to catch the end of a College football game. It did not appear that the 6300 covered the complete AM broadcast band. Is this correct? If you chose 160m it would go to approx 1600 Khz and if you chose band "630" you can get 550 to 670 Khz. Is this correct that the 6000 series doesn't cover the full AM broadcast band or am I do I have something set incorrect?
Try choosing GEN on the band select panel.
I have it doesn't show any signals between 670 and 1600.0
or just type 1.400 in to the frequency box...simples?0
I'm not saying you can't select the freq, there are just no signals between 670 and 1600 Khz0
Check the antenna selection.1
I can confirm the 6300 DOES pick up local AM stations. I've taken mine camping several times and was able to pick up "local" stations that were now an hour drive away.0
Can you post a screen shot of your SSDR window? Might help figure it out.0
mike, something obvious changes in your setup then. I use a 6300 and it is fine. Suggest you slide up from 160m and you may find that the selected antenna sockets changes over, or Attn goes on, or agc-T is very low there, or something like that!0
Ugh, like I said I figured I had something set incorrect and that was it, ant choice. I purchased the radio from another ham. I'll have to watch what is set up since I don't know how it was used before purchase.0
Yes the antenna thing got me too. I found a case where if i just slid my panadapter back and forth it would change between ant1 and xvrtr0
These things caught me out no end when I first became an SSDR user and still occasionally do.
I stayed on ant.1, switched to 160, collapsed the panadaptor till I could see from 0.0-6.4 mhz.
You can then expand the panadaptor to show the "closer in" view you may be accustomed to. I didn't notice an indication of it being in General rx mode, except for the unlocked padlock.
- 339 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 172 SmartSDR for Maestro and M models
- 405 SmartSDR for Mac
- 265 SmartSDR for iOS
- 248 SmartSDR CAT
- 186 DAX
- 372 SmartSDR API
- 9.2K Radios and Accessories
- 19 Aurora
- 196 FLEX-8000 Signature Series
- 916 Maestro
- 888 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 745 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 964 Third-Party Software
