Here's a suggestion for FM Repeater use.... Hint, Hint, Nudge, Nudge...
Roy Laufer
It would be REAL NICE if there was a setting to notch out the PL audio tone of FM Repeaters....
My system really reproduces lower frequencies well...
Just saying...
Just saying...
Can you not use the receive equalizer to cut those low frequencies? It may not completely eliminate them, but is should reduce the "sub-audible tones".0
This is a good point. Most FM radios roll off the audio below 200hz before it gets to the speaker. You could do this in the EQ section as well.
Mike va3mw
Been there, tried that. My sound system needs more low frequency attenuation to get rid of the PL tones I am hearing.
...and a bug in SSDR 1.5.1, that I discovered, disconnects the Receive equalizer from a slice added to a panadapter already open (I'm waiting for 1.6 to fix this particular bug)0 -
You can also edit the filter low side on the memory form and create a custom filter that starts at 200Hz, that might also eliminate the tones. Although you'd have to select the memory in order to use that custom filter. FRStacks could alo be used to save the custom filter.
73, Jay - NO5J0 -
You must have SSDR 3.0<grin>, my SSDR 1.5.1 doesn't have adjustable filters for FM.
AM, SSB, CW - you can filter to your heart's content. FM - no way Jose!( I mean Jay)0 -
Well I admit I don't use FM at least, I forgot about the the fact that it using a filter centered on the carrier. So ignore my post, there's no way
my idea will work.
I've been wrong before, but it still kinda smarts.
73, Jay - NO5J0 -
Don't sweat it! None of us are infallible.
The smart ones already know that lesson!0 -
The Smartest ones know to keep their mouths shut until after they have verified that their "I bet this will work" method actually is possible.
That proves how smart I am.
I think I'll attempt a little verification next time.
73, Jay - NO5J0 -
I too have this problem and losing most of the bass with the equalizer really makes listening less pleasant. Since the radio already knows the tone being used, why not an automatic notch filter for the received sound?0
If this were an old bit of film noir, the solution would be as simple as offering the right guy a "a Benjamin" or two. In our world all we can do is beg and wink, wink, nudge, nudge...
Goes the same with the ability to port transmitted voice into the DAX receive channel, so that both sides of the QSO can be archived...
It just requires the time and the effort, and, of course, the motivation.
Anyone want to get a "slush fund" set up <grin> (it works for most governments)!0 -
Being aware of our faults and limitations is the greatest of lessons.
Unfortunately, I have met too many people who have never learned that lesson..
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
