setting up asus RT-AC3200 VPN for iPad remote access?
David Decoons, wo2x
edited June 2020 in Third-Party Software
Hi All,
Has anyone been able to successfully set up the Asus RT-AC3200 (or any other Asus router with built-in VPN) to have their iPad using Stu's remote app access the Flex from a remote network?
Using PPTP VPN in the Asus router I can get the iPad app on remote network to see the radio but when I connect I get a black screen and then the connection times out.
I'm looking to have the Asus router provide the VPN server connection and not any software based solution.
  • Lawrence Kellar KB5ZZB
    Lawrence Kellar KB5ZZB Member ✭✭
    edited February 2017
    Yes  I use this exact setup.  Youtube has some wonderful videos.  Also a pleasent surprise for Mac users is that this device emulates a time capsule
  • David Decoons, wo2x
    edited June 2020
    so you are connecting with the iPad to the radio using Stu's app?
    Yes I am
    edited June 2020
    Can you share your router settings? I can see the radio in the chooser screen on the K6TU remote app but when I select it I get a black screen and it fails. Thanks Dave
    Email me your phone number at KB5ZZB@gt.rr.com and I will call you and try to help. Lawrence
    edited June 2020
    Hi All,
    I talked to Larry on the phone. The router settings were fine. The problem wound up being my home network and the LAN network on my cell that I was using as a mobile hotspot were both set to 192.168.1.x.
    I changed the cell phone hotspot settings to 192.168.25.x and all is well now.
