Wideband signal strength meter
Peter Driessen
A meter to measure the aggregate signal strength observed by an SCU would be very useful to quickly determine if the total input power including out of band signals not visible on the pan adapter exceeds the safe limit of 9 dBm
6
Peter:
Great idea! I would also like to propose a small (and possibly obscure) variation on this theme:
In EME and LNA development work, it's very useful to be able to measure SUN and MOON noise relative to cold sky. Sun noise can be as high as 10dB above cold sky but moon noise is an order of magnitude smaller. I've done this using my FLEX-6700 on 10GHz (using a 144MHz IF) and visually the panadapter is very well suited. If FlexRadio were to decide to implement a WB-SNR meter, please consider adding a Relative Mode with 0.5dB, 1.0dB, 2.0dB, 10dB and 20dB Full Scale ranges - RELATIVE to a "Zeroed" cold sky or baseline noise measurement.
Greg Jurrens - K5GJ
yup as a bouncer I like this
you QRV 3cms EME Greg??
Simon - QRV tropo and trying to get to the moon. I have everything but enough PA. Had the opportunity to press. The 6700 into 3cm EME last Summer with Al W5LUA. Performance was great! Can't wait...0
The wideband signal strength meter will help set up the 6700 for FDX SO2R with confidence that safe limits are not exceeded for the pair of antennas used.
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 983 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
