Uninstall DAX
Robert -- N5IKD
How do I uninstall DAX?
In previous versions it was listed as a separate item in "Programs and Features". It is no longer listed as a separate item. While it is listed as a separate item on install, it is grayed out so that it cannot be deselected.
I am putting this on a machine that will only connect to the radio remotely, so DAX will not be used and in fact gets in the way when manipulating sound settings.
You can manually uninstall and install from the driver directory for each.
C:Program FilesFlexRadio SystemsSmartSDR v1.5.164-bit Drivers
But DAX can also be used remotely... If you wish....
AL, K0VM
Follow this.... just dont reinstall
https://helpdesk.flexradio.com/hc/en-us/articles/204017069-How-to-Manually-Re-Install-DAX-Drivers
- 379 Community Topics
- 631 The Flea Market
- 123 SmartSDR+
- 193 DAX
- 39 Aurora
- 948 Maestro
- 925 Genius Products
- 337 Tuner Genius XL
