6300 and QC-15/Headset buddy combo use
Mike Member ✭✭
It's been a while since I've had to use an 8 pin mic connector.  What is the correct adapter/settings I need to use an electret mic with a 6300?  I have ordered the Maestro so I know this will be easier when that arrives but till then??  Thanks
  • Mike
    Mike Member ✭✭
    edited November 2015
    I'm coming from a K-3 and use a QC-15/Headset Buddy.  With the K-3 it was a matter of moving a jumper in the Microham interface and switching a menu item in the K-3. (you guys know anyone that wants to buy a K-3??  LOL)
  • K9DUR
    K9DUR Member ✭✭
    edited January 2017
    Mike,
    The mike connector is wired like a Yaesu 8-pin connector:
    Mic(+) = Pin 8
    Mic(-) = Pin 7
    PTT(+) = Pin 6
    PTT(-) = Pin 5
    Open the Settings.Radio Setup window & select the "Phone" tab.  Click on "Bias" to turn on bias voltage for the microphone.
    73, Ray, K9DUR
  • Mike
    Mike Member ✭✭
    So my left over adapter for the MP should work and just click bias on.....simple enough. Thanks Ray.
  • Michael Coslo
    Michael Coslo Member ✭✭
    edited April 2020
    I have a adapter that I made for a Heil Icom Headset. that I ended up adding a jack for a footswitch and momentary up and down switches as well. Works great.
    If you are interested, let me know and we can trade email addresses and I can email you the schematic.
    side note - does FlexRadio have a files section? Might be nice if their social software allows attachments fo files.
  • Tim - W4TME
    edited December 2016
    The Community software does provide facilities for file sharing.  Part of the reasoning is to minimize the possibility of mass virus infections by proving a place where lots of people can down easily load a common file.
  • Michael Coslo
    edited May 2016
    Okey Dokey, I'll check it out. Thanks, Tim.
  • Michael Coslo
    edited May 2016
    Hi Tim - I'm sure I'm going to feel pretty dumb, but I can't find the place to upload the jpeg of the schematic of the electret to FlexRadio adapter.
  • Chris DL5NAM
    Chris DL5NAM Member ✭✭✭
    Have a eye at lower right corner: Upload Image ( and a symbol)
  • Tim - W4TME
    Drag and drop the image into the post edit window.
