Need the latest SmartSDR and Power Genius Software?
SmartSDR v3.1.12 and the SmartSDR v3.1.12 Release Notes. | SmartSDR v2.6.2 and the SmartSDR v2.6.2 Release Notes.
SmartSDR v1.12.1 and the SmartSDR v1.12.1 Release Notes. | Power Genius XL Firmware v3.4.16. | Power Genius XL Utility v2.2.10.
USB D-STAR BOARD
- 69 Community Topics
- 1.9K New Ideas
- 120 The Flea Market
- 5.4K Software
- 4.9K SmartSDR for Windows
- 35 SmartSDR for Maestro and M models
- 86 SmartSDR for Mac
- 143 SmartSDR for iOS
- 149 SmartSDR CAT
- 67 DAX
- 278 SmartSDR API
- 7.1K Radios and Accessories
- 5.8K FLEX-6000 Signature Series
- 555 Maestro
- 14 FlexControl
- 722 FLEX Series (Legacy) Radios
- 149 Power Genius Products
- 117 Power Genius XL Amplifier
- 10 Power Genius Utility
- 22 Tuner Genius
- 41 Shack Infrastructure
- 22 Networking
- 89 Remote Operation (SmartLink)
- 50 Contesting
- 127 Peripherals & Station Integration
- 62 Amateur Radio Interests
- 404 Third-Party Software
Well, that IS interesting then (if it plugged into the host "no so much", right?).
Anyhow, I just ordered one!
ETA: Apparently the USB device looks like a serial port (running at 460800 baud?) for demodulating the data. This is one of the modes supported by the DVSI chip itself, and the USB to UART interface on the ThumbDV is an FTDI chip. Very simple little device and very clever.
BTW, the same DVSI chip will also decode MotoTRBO, DMR, and NxDN. The chip is, unfortunately, not capable of full-rate P25 (P25 Phase I) decoding (it *can* do half-rate, for one channel of P25 Phase II TDMA decoding, however).
Nice!
Peter
K1PGV
VE2OLM Marc .
The ThumbDV supports some 60 different rate and type of codec including the one from System Fusion. We then have to use the same modem and data bits that are used by Yaesu to ensure compatibility. We'll be looking into this to see what is required to make system fusion work as well. We do have a lot of other projects under way and so this make take some time.
Also because we are open-sourcing these waveforms, it would be fairly easy for someone that understands System Fusion to add this mode using our D-STAR code as a starting point. I don't know a lot about their modem yet so I'm not sure what the challenges there will be or even for sure if we'll do it, but we're certainly going to take a look at doing it.
Bret
WX7Y
International DSTAR HF Testing Net – Winter Schedule –
Use your ICOM 9100/7100, or STAR Boarded non ICOM DSTAR HF, or the FLEX 6000 series radios with software 1.5 or better and the DV3000 card.
Here is some video of DSTAR HF Voice simplex on a 7100
https://youtu.be/f8_n-zWrdWU
We routinely have two way communications coast to coast and North to South, South to Canada, Europe and Australia. We have had two way contacts to Japan. And have been heard in South Africa.
We are on each band only for 5 min. or so as to spend less time, if the band is dead we move on earlier. You can go back to a good freq after the net.
MONITOR REF030C to coordinate. WE may need to move early or if the freq is busy. We do not want to step on any AM or SSB activity.
We also use a web page to keep track of who and where we are at - http://hf.dstar-relay.net/
You also can check-in to this web site anytime 24/7 to find a DSTAR HF Ham to talk to.
We will have a PRENET for 30 min. before the start of the scheduled time. This PRENET is for ‘FREE FORM” contacts. One should check the web site http://hf.dstar-relay.net/ sign in and find a working freq to work on. When the net starts at the scheduled time, please join the net and follow the freqs.
DSTAR HF VOICE SCHEDULE
Sat PM 7:00 E (2400Z)
Sunday AM 10:00 E (1500Z Sunday)(Spend more time on each open band, and start on 80m)
Sunday PM 7:00 E (2400Z)
Tuesday and Thurs night at 8:30pm E (0130Z Wed and Fri)
Check USB/LSB on freq to make sure the freq is clear.
SUNDAY AM, we start with 80m and work towards 6 meters.
h:00 - h:05 6 mtrs 51.180 DV for 5 mins
h:05 - h:10 10 mtrs 29.480 DV for 5 mins
h:10 - h:15 12 mtrs 24.938 DV for 5 mins
h:15 - h:20 15 mtrs 21.380 DV for 5 mins
h:20 - h:25 17 mtrs 18.148 DV for 5 mins
h:25 - h:30 20 mtrs 14.325 DV for 5 mins
h:30 - h:35 40 mtrs 7.285(or another open freq) DV for 5 mins
h:35 - h:40 75 mtrs 3.880 DV for 5 mins Backup is around 7.300. THIS ALSO APPEARS TO BE AN AM FREQ
NCS will check the freq ahead of time to make sure we don’t step on anyone 3KC up and DOWN.
See how to do DSTAR HF with an ICOM at- http://www.youtube.com/watch?v=oGF-qkdoid4
"Digital voice is defined in the Commission’s rules as voice (i.e. phone), not data, per Section 97.3(c)(5) of the Rules." Check out the most recent comments by the ARRL: http://apps.fcc.gov/ecfs/document/view?id=7521063715
Kent
KQ4KK
